I have a Cold Case radiator in my 68 Barracuda. I bought a kit with their fan shroud and electric fan BUT due to clearance issues I can't use the fan and shroud. I'd like to know what fan you're using and if you have a shroud what are you using?
Hi Ron,I have a Cold Case radiator in my 68 Barracuda. I bought a kit with their fan shroud and electric fan BUT due to clearance issues I can't use the fan and shroud. I'd like to know what fan you're using and if you have a shroud what are you using?
Beautiful work, and I am jealous of you guys that have the engine compartment clean enuf to eat off of!Maybe this might help as I ran into this common problem too. I have a Champion #526 radiator in my 72 Demon. 408 stroker motor. I looked at MANY different setups and ended up using a Jegs #555-52115 dual fan assy. It took a bit of fab work using little screws and such but I was very happy with the clean look once done. I control the fans separately with switches and to date, this setup seems to keep the engine cool even in 90+ deg weather. Some pics:
Here is the fan unit itself mounted to the rad before I stuck it in the car. Note that when I installed it, I also added some flat alum strips to close the open gaps where the fan barely extends past the rad on the sides.
Hope this helps!!
Thank you but trust me...there are people on here with MUCH nicer cars than mine!! I am on here to learn from so many people that have knowledge and expertise I don't have. The collective knowledge on here is tremendous and fun! And when someone has a bridge to cross that I already have, I try to share it in case it might help.Beautiful work, and I am jealous of you guys that have the engine compartment clean enuf to eat off of!
I decided on a reproduction 7 blade clutch fan and factory shroud #325 I bought from Mancini's. There is a gap between the shroud and radiator is it necessary to fill it in? Still has to be better than no shroud at all.
I am too detail crazy to let that big ugly gap go. I am going to find a way to fill it that looks good.
I hear ya man. I'm the same way. Here's how I ended up modifying mine. Whether or not it makes a lick of difference - I have no idea. I sleep better at night though.
I guarantee it's making a difference! Nicely done!I hear ya man. I'm the same way. Here's how I ended up modifying mine. Whether or not it makes a lick of difference - I have no idea. I sleep better at night though.
okay...so could you not shorten the brackets when you make them, and reduce the gap?I guarantee it's making a difference! Nicely done!
