73NorthernDuste
Hi Guys
I am swapping out my /6 for a 360. The engine I obtained had a 727 with it. I know if I keep the 727 I will have to shorten my drive shaft when switching from my current 904, but I have also read that the some of the column shift linkage parts will not fit right. Namely the cross shaft and the trans adjuster rod.
Has anyone done this swap and know if I can make my current parts work or does anyone have the right parts to make it work? My car is a 73 Duster original /6 with column shift auto. Thanks In advance
Brent
Brent
