nm9stheham
For the Wallace tool, you want to use the intake closing angle (ICA) based on advertised duration. Use that number 'as is' for most hydraulics.
That sounds more like it. My advertised dynamic was 8.19/1 and my @.050 was 9.08 with a 9.68 static ratio. I didn't think it could be that close.For the Wallace tool, you want to use the intake closing angle (ICA) based on advertised duration. Use that number 'as is' for most hydraulics.
Your instincts were right. Looks like advertised would need to be something like 225* for that close LOLThat sounds more like it. My advertised dynamic was 8.19/1 and my @.050 was 9.08 with a 9.68 static ratio. I didn't think it could be that close.
Another stupid question where do you get the ica ? I dont see it the cam specs?For the Wallace tool, you want to use the intake closing angle (ICA) based on advertised duration. Use that number 'as is' for most hydraulics.
Good question. That is the problem with the Wallace tool and stymies many folks, I suspect.Another stupid question where do you get the ica ? I don't see it the cam specs?
No we are not done hereAren't you guys done here? There's someone else that needs your help. Cams How do you choose one?
@dartfreak75 , sharpen up your pencil and see what's different with a low compression 360. That 268 cam would work good in a 360.
LOL I knew you would say that.No we are not done here
I'm still learning. We can multi task!!![]()
Lol you know me well.LOL I knew you would say that.
Maybe but I don't get a hangover,lolmessing with them calculators make ya brain mushy after a while.
Haha thanks that is helpful much appreciated!You want the Formula?
You know I got formulas..... right
Can I get a yes, yes?
OkOk you twisted my arm here it comes
It's coming out of my head so hang tuff, the wheel are turning.
Ok
take the intake duration and divide it by two, then subtract the specified ICL (installed CenterLine.) Take the result of that and add it to 360*. Now subtract the intake duration from that, to get the compression degrees. then take those compression degrees from 180* and out pops the ICA, I need an aspirin.
Now lets convert that to math....... maybe two aspirins; here it comes;
180less(Intake duration/2 less ICL)+360 -Intake Duration = Ica.
Example1
180 less{(276/2) less106)+360-276}=Ica of 64*. Hey it works!! And another;
180 less {(292/2) less104)+360-292}=Ica of 70* Badaboom that one too!
Lessee what else can I give away? anybody need a green couch?
Most all of the things you mention will effect how close you come to detonation:I know I'm not in risk or anything but if I were to build another engine say 10:1 scr and get in or about that 8dcr how do avoid detonation? Is is simply a change in fuel? Or can you do something to the combo timing jetting advance retard etc?
That's why some of us have kept poking at ya LOL. For a driver car, the throttle response makes it a loooot better. You potentially end up with a bit less peak HP but you more than make up for it with throttle response and an overall wider usable RPM range. Push up the SCR and then you can put in that bigger cam, get the higher HP peak (as long as the heads will flow), but the DCR stays up and you don't give up the low RPM torque.One thing i really want to have is that snappy throttle response I hate that bogged down rev. Like setting at idle in park/neutral and you hit the gas and you get that quick waaaaapa. That is what I'm looking for not that you hold it to the floor and it takes 5 secs to hit 3 grand roooooo grrrrrrrr..... lol
Kinda like drugs... not that I know firsthand, thank goodness LOLThe more I learn the more I want to know.
Thanks man yes it is.I wouldn't know either. It has been years since I have been in the car building game (other than working on my every day drivers) I thought I knew quite a bit now I'm realizing I didnt know crap lolThat's why some of us have kept poking at ya LOL. For a driver car, the throttle response makes it a loooot better. You potentially end up with a bit less peak HP but you more than make up for it with throttle response and an overall wider usable RPM range. Push up the SCR and then you can put in that bigger cam, get the higher HP peak (as long as the heads will flow), but the DCR stays up and you don't give up the low RPM torque.
Bore, stroke, rod length,Scr, Ica, and elevation
then go here,
Wallace Racing: Dynamic Compression Ratio Calculator
and pay close attention to the V/P, which you can read about that here
V/P Index Calculation
to get a picture of where you are starting from , plug 7.8 in for Scr and 50* for the Ica,These are the specs for a stocker with a 240/248/112 cam, in at 110....
plus the basics; 3.91x3.315, 6.123rods, and your local elevation; 300ft IIRC. I get 132psi@109VP, and you already know what that feels like.
I took the liberty to max out your compression for this cam, with a bore job and hi-compression pistons and retarded the FACTORY cam to a Ica of 53* so you can rev it a bit. This is about the max you could run on pumpgas. I get
Scr of 9.25 @161psi @132VP @7.97Dcr.
This would make a real stump puller, with fabulous first gear performance. and tons of grunt in second at say 30 to 45 mph just where you need it.
With 2.76s and the 2800TC, you won't get any better, to somewhere between 45 and 50 mph.
As a comparison this 132VP is more VP than a factory 340(128)calculates to , more than a factory 360(121)calculates to,and even a 440Magnum calculates to just (136) with the 4bbl cam.
And we haven't even talked about the fuel mileage improvement,or what the 4bbl and headers are gonna do for you. These V/P numbers are most valuable to know, from a factory stall to in the range of 3000 to 3500, after that the combo better be making power elsewhere cuz the VP advantage has diminished to nothing. That factory 240 cam is done pulling around 4500rpm. That doesn't mean you have to shift it there, in fact with the standard TF ratios, the 1-2 split is 59.2%, so for low-ET this combo might need to be revved yet higher, perhaps 5000 or a bit more.
And for anyone reading this that has a manual trans, you know how much time you spend from 1600 or so to 2800 or so. For you guys VP is really really important. If your combo is doggy in there, I know you ain't happy. And nothing sounds worse than a Mopar impersonating an old Mustang, having to slip the clutch out so it don't stall, and then rev it to near 4000 to find some torque in second; Man, I would be so embarrassed . With VP like this, and typical street gears,and street flywheel,you can just dump it and go. I'm not kidding. As a comparison my 367 calculates to 156VP and spins 295s/325s to waaaaay past the speed limit. I have to lift at 65,lol. Actually I have to cuz that is 6900 with my gearing,lol. Oh! we're not talking about high rpm in this chat,sorry,lol.
Ok so with my 10.97 starter gear, it really is a blip the throttle and slip it out, without any gas pedal, deal. It was pretty similar with a 9.44 starter gear. But with 3.23x2.66 it needed a bit of gas-pedal, and/or easy on the clutch pedal. This is where big VP pays off;throttle response and low-rpm driveability and the ease of initiating tirespin without racegears. 156 is a lotta,lotta VP. 132, as you can see, is quite a bit.
HyupAJ the Hughes/ Engle were .008 most likely .006 now
Good numerical perspective on low RPM torque.... but you can be sure it GOES anytime you push on the tall pedal on the right, no hesitation. With a manual trans, start out in 2nd. Ford C4 and C6 trans had the feature that you could start in 2nd gear too; can you do this with a Torqueflite? (I just never paid attention...)156 VP is a snappy engine.
I have VP 152 in my duster with a 340.
And a VP of 155 in my old 360 truck de-tuned down from 212 in my old truck with a camshaft and head-gasket change.
Both vehicles built with the intended use.
The old truck is a complete torque monster spins the tires on the on-ramps on the interstate in 3rd gear, not just a chirp, fish tailing, its a 4x4 with a 4 speed, stock tires.
My wife says I ruined it for a winter vehicle, too much power.
