Just look up fuel kits
Lines from and to the tank and filters.Carburetors or like fuel tanks/fuel modules?
Yeah. Not real hard. lolJust look up fuel kits
that's the route i went.So on third thought…
Tanks inc efi tank with efi pump regulated (with return) down to 5-7 psi. Fuel filter back by tank. Steel braided or hard lined (-6) to front. Mount regulator close to carb as possible without being on fire wall or on top of exhaust manifold. Build fuel log to chosen carb.
Much more expensive. But hey.
I’m not so confident the pump can be changed without removing tank, but they say it can…. Either way, that’s the one. Might find it cheaper someplace but summit is usually the lowest??
After all fittings, pump and lines, you are getting up there in price.
i don't see why you couldn't use the hard line. i mean, it may not pick up in the stock location so you'll need to cut it wherever and then just use a soft/braided line to whip in with a fitting.Lines I’ll have to figure out (unless I can use the hard line I just bought last night) fittings too, but the pump and sending unit are included.
