i was reading another thread and thought i had a 7 1/4 rear end but after reading it i counted 10 bolts.... its a 72 demon that had a /6 and it had a gear tag of 2.45
Sep 10, 2010 - 3 posts - ‎3 authors
I recently got ahold of a 2852905 casting 8-1/4" rear end. It is complete with a 3:21 gear ratio, and is exactly what I want for the Dart. 69-70 8.25 need help/info please - Transmission and ...
17 Aug 2012
i felt up in there i had to squeeze my hand in there and feel around i just went and double checked and there are 10 bolts and its pretty rounded no flat ends so im guessing its a 8 1/4 but does the gear ratio sound right
ok next question lol i know that the 2.45 gears are less desirable and i want something better so what would it take to put better gears in it and what would be a good ratio for a high performance 340
You'll need a different 8.25 housing (2.76 and higher have a different housing). You should be able to find one pretty easy if not the 8.75 is always a better option. That or go full out Dana 60.
