EDMOPAR
Hi, to all, Finally fixed my cooling system problem, 76 duster, 72 340, 22" Champion Radiator with (2) ten inch fans, high performance pump, change thermostats, drilled holes in thermostat, changed timing, car would heat up to 210 and above, I finally ordered a 18" clutch fan assembly and shroud from Mancini Racing, installed with a 180 thermostat and now temp runs around 183-185 and goes no higher than 190 when I stop or in stop and go traffic, this has been a pain in the u-no-what, I also called Ledfoot Racing, this is where I purchased the setup from and they offered me no help what so-ever, except to sell me another set-up, the set-up was supposed to cool 550 hp, I may have 350 hp max, this may help someone going through the same problems. Have a great day, Edward
