Also look at the Burgundy paint on the Dart
All door jams, trunk and engine bays painted black
I know the guy that built these cars at hurst. These are his pictures he took at work.Very nice Dave, thank you very much for sharing.
With everything being said I would love to see photos from back in the day with a seat in a BO or LO folded forward……just one. I’m not saying I don’t believe everybody but I sure would love to see it.
There is no assembly line at hurstPLEASE EXPLAIN TO ME WHY THETE IS A “ENGINE STARTING” TAG IN THIS CAR!!! Those were installed at the end of the assembly line…..I thought these cars were pulled long before then! I give up!!
SSing look at photo on number #49. Good photo.
Yes, good picture and considering it is taken from an angle from behind, the gap between the tire and the front lower lip of wheel well, is connciderebely bigger than on production cars, even bigger than on this Dart...
Note (about the same angle) on the production car how, at the bottom closer to the rocker, the wheel well line cuts in sts.
We are talking an inch at the most, at the very bottom, that was cut off at some point...
I don´t beleve this myself really, but is it possible rear quarter was prefab at Chrysler, on the bodies that vere ment to be shiped to Hurst. Think they had the time to do so on the first run of Cudas... second run not likley...
How tall are the tires, on cars leaving Hurst?
Edit.
I have now found the picture I first made to compare and saved, when i saw the picture of the Cuda taken at Hurst and posted on a forum a couple years ago. This picture of a production Barracuda, is taken from close to the exact same angle as the Hurst pic. Acctually a little further forward, witch makes the wheel well line go more stright, making the difference look less compared to the Hurst picture.
Disregard the three picture shown in this post.
I post three new picture in next post.
Remember, we are talking some 1" at the most at the very bottom of the wheel well. Inside is the wheel tube. Cutting line than gradually goes upwards to meat edge of wheel well some 10 inches up. So not a whole lot has been cut of.
I have earlier posted picture of the Mule Car, that also have this cut done.
Here are the new pictures taken from very close to same angle.
Yes agreeCorrect but there is a big difference between Feb 1968 and June 1968. Just wondering…
One thing WE need to consider is the offset of the BO wheel is far more than those of the painted wheel. The wheel is pushed in away from the lower lip making it look like there is more clearance. The tire on the painted wheel IS closer to that lower lip because of the wheel offset is stock.
Yes that is correct, I understand that, but still, the lines are not the same.
How tall are these tires from Hurst?
And what is your take on the fact the Mule car had the cut made, as I have shown in a post in another thread?
