OK, without a complete step by step, how does the shaft come out the bottom after I get the column out? Thanks
If you're pulling the entire column out, the shaft can come with it. Just remove the roll pin that holds the shaft to the gearbox. The picture of my column hanging from the ladder when I painted it shows the entire column with the shaft.
