Now THAT is purdy.....yes it works on my all motor pump gas street car! RACED on pump gas 93 btw! no mixing shyt like some of these guys on here.... and NO my dipstick tube don't pop out on the big end with may steel tops and napier 2nds.
Anyone do a before and after?
Well if you are really looking for a performance gain then a vacuum pump set up is where it's at. Could be worth as much as 30 HP over the pan evac system.
Hey Dustpan, that's a neat set up there. I was thinking of adding in a seperator like that on mine to keep oil from getting into the exhaust. How are you pulling vacuum on the canister - one line or two?
So you're using the normal header collector pito tubes and check valves on both sides and then run both lines into the canister to pull the vacuum? Does that canister have a drain to remove oil - what brand is it? Does the top breather work off a pressure (vacuum) switch of some sort or is it open to atmosphere all the time? (Sorry for so many questions).
