Dartswinger70
Man, that's a real "head scratcher"... ![:thumbsup: :thumbsup: :thumbsup:](/mopar/styles/default/xenforo/smilies/ATT00014.gif)
After cleaning firewall terminals, only red female battery terminal was removed and wire brushed, car started even though battery had not been on charger for two days at 12.7 volts. Haven't checked Ign 2 volt drop yet but seems to consistently start without putting battery on charger. Drove car around for 40 minutes Anp Meter stable slight charge but needle on white middle mark. After drive battery was 15.2 volts engine running before I shut engine off. Alternator stud is 15.4 volts and if I unplug VR it goes down to battery voltage.It would be better to replace those terminals. Some of the supply sources have changed/ dried up so you will have to search. "Packard 56" and various. Be CAREFUL that the terminal has the tension area wrapped around the sides as exactly in your photo. There are some different ones that bend over the top and they will not fit some Mopar connector shells
I know Mattox has done some posts on this.
The other thing is, if you get this finally settled down, working, but still have some voltage drop in the IGN1 "run" circuit, that will cause overcharging as the VR sense will be low
One way around that is to electrically break the "run" IGN1 coming out into the bay, use the end from the switch to fire a relay, and supply the relay contact power from say, the starter relay big stud, and then put all the underhood "run" loads on the switched contact.
I have the correct terminals on hand.Once again, what I could SEE in your photo indicates corrosion, and the two most important terminals IN THE ENTIRE HARNESS are the big red and the big black ammeter circuit terminals. I would replace them
I been reading up on relay mod. Its much more precise if VR gets its voltage straight from battery via relay vs a maze of connections/switches/hops.Progress however slight. Don't forget that drop (and it can come and go) can be right in the contacts of any switch. Part of why relays are useful
The Unilite ignition module is dead too. So maybe I join the Unilite haters crowd? Cause I think I am starting to lean that way?Wow, man, never seen a mess like that.
This is aggravating me and it ain`t even my car.![]()
Cap and rotor from 2009 ?Wow, man, never seen a mess like that.
The rotor may have been from 2009 but may have replaced some time in between. Rotor was in very good condition. Cap is 3-4 weeks old.Cap and rotor from 2009 ?
Unilite module is no spark and doesn't draw any current any more. Cap rotor toast. So even though Unilite ran fine for 15 years trouble free do I replace module/cap/rotor or switch to something else?I don't know anything about unilites but I would be tempted to swap it out just to change the problem. Either just slap a breaker points dist in there, or find a Mopar stock breakerless dist and look up the HEI module conversion. It is not very hard.
That all makes sense, right?. Drove car around for 40 minutes Anp Meter stable slight charge but needle on white middle mark. After drive battery was 15.2 volts engine running before I shut engine off. Alternator stud is 15.4 volts and if I unplug VR it goes down to battery voltage.
I measure 4.6 amps between Ign 1 and VR and 4.8 amps across field circuit. Was 3.4 amps a week or so ago.
The difference here is current. With the Unilite plugged in, more electrons are trying to get past the resistance. Since the power is coming from the car's battery the increased current with the Unilite plugged will be indicated. it should take quite a bit more current to cause a .5 V increase in votlage drop.If I jump a wire from + battery to Ign 1 at ballast resistor connector (key off) OR put key in Run I got the following:
Ign 1 at VR: 1.3 volt drop
Ign 1 at VR, Unilite unplugged, .8 volt drop
The rotor for my Unilite 47 series distributor, MAL-322, is discontinued. Was hoping to put a Pertronix conversion kit, they have one specifically for Unilites, but without a rotor that distributor is now a paper weight.I don't know anything about unilites but I would be tempted to swap it out just to change the problem. Either just slap a breaker points dist in there, or find a Mopar stock breakerless dist and look up the HEI module conversion. It is not very hard.
