Crankshaft Retaining Tool
dibbons
La Paz, B.C.S., Mexico
I often struggle trying to keep the motor from turning over (torquing crank bolt, flywheel, flex plate) by sticking a bar or large screwdriver in places they don't belong. I had my local fabricator/welder make me up a tool to take care of that task for me under most circumstances. However, when I got the tool home, I found we forgot all about providing a hole so I can tighten the crank bolt to specs (see photo #1). The remedy will be to cut out a 2 1/2" hole in the tool (should work better with that modification) (see photos #2 & #3).
Rope trick.
Pick a cyl pull the spark plug
find tdc on that cyl
Back off 1/4 turn
Feed cotton cord into the cyl
Rotate back toward tdc.
Cyl compressed the rope.
Engine no longer turns over
I made one out of piece of scrap 3 inch angle iron that I cut a notch out of for a crank socket and welded a flat bar to. It's crude, primitive, catches three balancer bolts, and is about as pretty as a mud fence. But it works!
I put a deep socket in one of the balance holes and run the crank until it hits the block. Doesn't help with the pan on.
