Anybody running a cross ram with 2 four barrels on a small block? Other than being totally cool looking is there a benefit? I have a lead on a cross ram intake and want to know if it's worth the time and expense (Yes it's expensive)
And the color is perfect. That car looks badass.The only thing I see is with all the new heads out there for Small Blocks. You are limited to stock designed ports. Although They do look cool for a street car. I bet it would work good with two Holley Sniper 4150's on it. Otherwise jetting would be a nightmare. The Hemi Cross ram holley carbs have all different jets in every corner. My friend has a hemi with a cross ram and it took special carbs and jetting.
But boy does it look good on there . I performs as good as it looks.
But its a cross ram. They were cool looking on the Max Wedge's and the 67 Z28's Tuning them is the head ache. Bryans was built and dynoed at Ray Bartons . There is a science to tuning those intakes. They are not like tuning a inline style.Although not exactly a small block either...
It went to a place that knows how to tune them, no doubt about that.But its a cross ram. They were cool looking on the Max Wedge's and the 67 Z28's Tuning them is the head ache. Bryans was built and dynoed at Ray Bartons . There is a science to tuning those intakes. They are not like tuning a inline style.
As do ld340's, rpms, air gaps.Is it worth it? It is to me! It makes more bottom end than the 750/strip dominator it replaced.
I went the other way. I thought the 650/Strip Dominator had more low end and I didnt think the top end lost any. I had 2 390's on my 340 (then went to a single 4bbl top, maybe that killed the ram effect?): 284/.484 cam MP 175K convertor, 3.91 SG. Only response I got on my STR was "why did this guy put a Chevy motor in this Mopar?".... dumb *****.......Is it worth it? It is to me! It makes more bottom end than the 750/strip dominator it replaced.
If u want one buy itAnybody running a cross ram with 2 four barrels on a small block? Other than being totally cool looking is there a benefit? I have a lead on a cross ram intake and want to know if it's worth the time and expense (Yes it's expensive)
