dans4door1970
What are your opinions on these in an exhaust system. My old time Mopar mechanic doesn't feel there are any benefits and installs exhaust systems without them.
I don't like the crossover cause it usually captures the tranny. Think I'll leave it alone. ThanksCrossovers are for mellowing the exhaust tones and increasing torque.
X pipes are for higher RPM exhaust scavenging. (and they can mellow exhaust tones due to the pulses running through each others paths)
One thing a lot of people don't seem to know is a crossover belongs way up close to the motor, and X's belong way towards the end of the exhaust. (behind the axle on a full system) or as far back as it can be done.
Do we really need them? not really.
Do they both have a purpose? absolutely.
The "H" pope should be no further back than the trans crossmember.
The "X" pipe crossing should be placed at the crossmember. Only because a driveshaft would get in the way any further back. Any further forward, you have a transmission in the way.
The H & X pipe helps balance pressure between the two side but the edge in performance goes to the X. It works a little better and helps with a few more upper RPM's.
The power differences have been documented before via car magazines. The difference amount is build and power level dependent. You can not blanket the gains by saying "yyy" amount for anH pipe and "eee" for an X pipe.
For sure. it runs great without so, don't mess with something that's workingI can say that all the dyno work I did on V-8's I never saw a gain in either system, other than maybe a bit somewhere are pound peak torque. It usually rocked the peak a little. To me they are both worthless, unless you specifically engineer the entire exhaust and induction system for either one of them, and are concerned with a very narrow RPM range.
I have seen import guys dyno multiple exhaust systems at a time, back to back to back. When it was all said and done, the stock exhaust was the least power, but the aftermarket junk, with the doodads and such, were only marginally better.
This reminds me of a joke
What does 80 year pussy taste like?
Depends.
There isn't a solid answer to the question. One combo may not like a crossover or X pipe and others will. It's that simple. There is NO WAY to answer the question on a substantive basis to cover EVERY combination. PERIOD!!!
I have the California mufflers with the quiet disc in them straight out of the headers. Sounds incredible, runs fantastic and no clearance or weight added. I'll stay with them. Every time I hit the key and it rumbles to life, I get that feeling of pure bliss!!!YR, IMO, to much time and money are lost on the worry of not getting it all. On the "In general" hot rod and street striper the owner will loose more races than his car will.
I can Totally dig getting the most out of your build though. I myself am just not that worried about it. When the car is racing for the money, the game changes. I'm not racing for the money in the street. My tude is, "Ya wanna go? We go. Keep your money, I am." I win, I win, I lose, then I loose."
I have always run one, if nothing more than for the changes in exhaust tone. Seems most people won't dispute that purpose. Not everything we do to our cars is simply for added power.
I've read some things supporting X-pipes and others making them seem marginal. It seems very combo dependent.
My 2 cents, your mechanic is as you said, "old school"
I wouldn't go without one of the 2 and will always run an X if possible. unfortunately I had to run an H on my current car because of the GVOD.
I just googled car chemistry and don't see them.I've got the Car Chemistry mufflers with the quiet disc straight out of the headers and man they sound sweet!!! no changes coming here, I was just wondering for future builds
Go to summit racing. they have them. I bought the 3 1/2 ceramic with the 3 disc street setup. They are awesome and turn down under carI just googled car chemistry and don't see them.
Do they look like a Custom Craft muffler? That you can find on google.
I just looked them up on yahoo and it showed up. jegs has them or you can buy directNever mind. That's what I run. Thought it was custom craft.
I've been using muffs like this since about 1992-1993.
Nice and growly.
So, old school is bad? Just for reference.
Then again, if it works, leave it aloneOld school isn't always bad. Technology and product availability has come along way since the 1960's. I'm just for taking advantage of the worthwhile improvements.
If you don't want a crossover, H or X, then don't run one. Simple.
Old school reminds me of the guy in my town who swears by his Mallory dual points, his thermoquad, his flex fan, his tiny rappy exhaust and his .509 cam. He gets his *** mopped and leaves the car home on hot days. He talks down on mine because I use new stuff that either isn't as good as the old stuff or ruined the car for taking the factory stuff off.
