do you have repair manual yet? a wise investment from what I'm gathering
Duey, you need to go to the local parts store and ask for spark plugs for a 78 Cordoba with a 360 eng
I don't care what brand! get 8 or maybe 10 that way you have a couple spares to swap around.
I know your dying to install that manifold but lets give each cyl a fair chance at firing First.
What's valve timing? Is this where the cam is installed slightly advanced?
sounds like valve timing to me
A simple yes or no could have worked. I looked it up. Basically it's exactly what the name states. The time when your valves open and close and, yes you control it with the camshaft in how advanced you make your cam. I believe that's where the dot on the timing chain gears line up. Yes they are lines up pointing towards each other
Ok look I made a list about 2 pages back of things I have not tried. Today is Saturday. I work till mid afternoon then my plan was to come home and finish up everything I haven't tried. You're right it could be just as simple as the carburetor not running correctly. Why is it that it ran just a few months ago on a 318 I had? Tuned and adjusted and everything. Why all of a sudden is it not working on this one? Vacuum leak?
So yes the rest of the recommendations will be tried today. I really do hope at least one of them solves the issue.
you need to put spark plugs on that list!
Them plugs look like they have been in there for a long time. if they are fresh plug, you have a way rich mixture going on aka carb issues.
If you bought them plugs, the parts man gave you a couple of plug that are not like the rest of them!
Get some fresh ones and make sure the parts guy give you all same part number on the plugs.
DON'T LET ME GET YOU OF TRACK! THAT LIST YOU MADE IS A VARY GOOD START IN THE RIGHT DIRECTION.8)
Sometimes in reading through all this I think he needs to get together with ONE person and start eliminating ONE possibility at a time.
Everyone throwing thier thoughts in randomly might really be causing a lot of confusion.
I'm almost positive the problem has been run across already and not solved.
Like Rob said, "There are only four things that an engine needs to run" and we seem to be going around in circles instead of a straight line of simple diagnostics.
Why is it that it ran just a few months ago on a 318 I had? Tuned and adjusted and everything. Why all of a sudden is it not working on this one? Vacuum leak?.
Does anyone live near this fella, that can go help him out? Maybe the OP can buy some pizza/sandwiches and beverages to get this thing worked out. Anyone have a good spare carb that can sell to him or let him borrow? 10+ pages later and this thing still doesn't run. Let's get this thing fixed.
I have all 8 plugs the same. Remember I replaced the 2 dead cylinders with different plugs to see if it would make any difference.
