Is that silicone or sealant of some sort plugging the hole and smeared on the flame deck surface?
I don't disagree that it looks bad, but evidently, somehow it worked.I just say ugly as it doesn't even cover the whole flame deck surface. As horribly drawn below, I would worry about a pathway for cylinder combustion to cross talk.
Keep in mind, he is in another country. Someone probably did about the best they could. Not everyone has access to half million dollar machinery.Is that silicone or sealant of some sort plugging the hole and smeared on the flame deck surface?
Oh, I agree. Just areas of concern. I also said it can be fixed better and used - most likelyKeep in mind, he is in another country. Someone probably did about the best they could. Not everyone has access to half million dollar machinery.
The whole area was covered in dirt grease and was basically all black, actually tool the head off yesterday and didnt even notice that it was repaired, only seen it today when I cleaned up the blockIs that silicone or sealant of some sort plugging the hole and smeared on the flame deck surface?
that's a whole bunch of cam for a 318 with that compression.......and the 318 is a 1969 with the higher 9.2 compression I thought ill just clean up the bottom end, put the aluminum heads and air gap on, and a comp XE274 cam which I have laying around and see how it works.
Yeah, I agree. I bet it could look a whole lot better just getting decked.I’d deck it flat and send it. It looks like someone goobered some weld on there and did a quick file job to get it down the road.
JB weld looking repair. Personally unless it is a “numbers matching” restoration, I would just find another 68-71 block.That looks odd and shoddy to me.
I have never seen a repair like this before from the factory.
Did it run okay and seal before you took it apart?
Or, have you never run it?
I would be looking for another block to build if it were me, after all, it's only a 318 and there are a lot of cores around for cheap.
That's my take on it FWIW...
Looks like a shabby weld repair with high nickel rod. You being in Austria, blocks are not around every wrecker. VW blocks yes. I would take it to a trusted welder. They can grind it out to the parent iron metal and furnace weld with cast rod, or pre heat the area and cast iron weld. Keep some heat on and peen while cooling slowing to relieve stress.Hey all,
I just teared down my 1969 318 engine and found this (see pictures) between cylinder 4 and 6.
As I thought I removed the thin stock looking head gaskets I wondererd if this is maybe done by the factory? Anybody seen something like that before?
Actually I wanted to reuse the stock bottom end...
Thanks for the help!
Not brazed as the brass rod is decidedly amber. That is high nickel rod, arc welded. I have seen a number of heavy duty blocks repaired this way. Always looks like stainless against the iron.That looks to have been brazed...can you confirm? I agree on brazing it up the rest of the way and decking the block .The extra compression will wake that 318 up.
True that. Brazing it would do that.Some of you guys are posting up suggestions needed for a crack. All this block needs is filler metal and can then be filed flat with a file. Ask me how I know.
Brilliant!!!
