Hueyjockey
I just pulled the motor on my ‘65 Dart GT, 273 2BBL! The plan is to rebuild it to OEM 4BBL specs....for the most part. I have acquired an Edelbrock D4B intake to top it off. The D4B is about 1” taller than the stock 2BBL intake. I was wondering if I will have hood clearance issues with this intake? I can replace the motor mounts with the local parts store mounts that they say are correct, but they’re really not. These mounts are about an 1” thinner than OEM mounts. This will solve the intake issue, but may cause exhaust manifold issues with the power steering box. If any members have experience installing the D4B, I would appreciate the lessons learned! The carb will most likely be an Edelbrock AVS2, 500 CFM.
Thnx...
Thnx...
