Dart convertible to 4 speed
superbirdrag
Hi
I cant find any where in the threads that says if you have to remove the complete automatic pedal and upper brkt to install the 4 speed pedals set up. It looks like I should be able to just swap the brake pedal and add the clutch and appropriate brkts.
can anyone have info on this ?
Yeah I just unbolt the automatic brake assembly and bolt in the stick shift Brake & Clutch assembly easy as pie.
Hi
