justswinger
Member
- Joined
- Jan 22, 2009
- Messages
- 16
- Reaction score
- 0
i am wanting to install headers on a 70 Dart Swinger with a small block auto with ps & ac is there a header that fits better than others or do they all have issues going in
I would spend the extra money on TTI's. Just installed Doug's D453 on my Demon and would not reccomend them to my worst enemy.
their step header is misleading since it wont make any more h.p. more than a cheap set of 1 5/8s.
Sorry, but your statement is very "misleading", whether it was from personal experience or second-hand! What's your side of the story?
Here's mine:
http://www.moparmusclemagazine.com/...0307_mopar_crate_engine_exhaust/photo_17.html
....and I've run 11.31 @ 115 with a 360, unported set of 1.88" valves, .474" lift cam weighing 3,540+ lbs. Other, similar lighter combos have been in the 10's with TTI's 1 5/8"-1 3/4" step headers.
Easiest headers I ever installed and some issues can be attributed to problems with the vehicle itself after 30-40 years of use!
Admittedly, I look for little gains because of the rule restrictions. But the small block step headers appear to work well in mild as well as some race combos as shown by my examples. They also have the advantage of thicker materials, eliminate the need for a 90* oil filter adapter, have no issues with speed bumps and mini-starters aren't difficult to remove & replace. Inner & outer coatings also need to be factored into the comparison.
But true, they aren't for everyone. Many feel the advantages are worth it and they are made in the USA. But there will be issues with any product for whatever reason. Can't comment on their bigger headers because I never needed them. To each, his own.
dougs are supposed to be alot like tti but i have never personally used them so i don't know
I can appreciate that,also its a pretty unique deal when your racing with limits like you are and as crackedback said step headers work in a very small window so if your in it they could be of some benefit.I would be skeptical though of any increase over low,low teens for h.p. and only in a small rpm range and they defintiely do not flow as well as a true 1 3/4 header.Step headers were a fad long before tti had them and their pitch was the torque of a 1 5/8 tube while still maintaing upper end h.p. but we all know there is no free lunch.I know of alot of small block cars running 1 5/8 and running very well,12s to 11s,now these are cars that have ported heads ect but run on 3.55s to 3.91s so they are street cars.Ive found alot of it is based on cubic inch and rpm range,there is at least one calculator I stumbled across on a circle track site that seemed to coincide with what Ive experienced.I wouldnt run a 1 3/4 on my 340 in its current form (approx 420-430 h.p w/6,300 shift points) since in my experience it wouldnt add any overall power and minimal if any afect on e.t.s,but this could also help explain why tti elected to do a step tube design simply to try to acheive a happy medium.At any rate its hard to beat a straight 1 5/8 or 1 3/4 since in the proper application either will make more overall power than a step tube design.
Suppose to be is correct..but their NOT!!..friend of mine put them on his '70 dart,had a problem with the 2 center tubes on the driverside hitting the streering column,he had to add a few shims to get them to clear,
Same thing happens with tti headers. It's sloppy car building tolerance and years of use that you refuse to accept.
I can accept facts,fact is it DIDN'T happen installing the tti's on both my dusters..
