Enjoy the next step on your journey of life, that's what it's all about.
We have no clue what is in store for us in Missouri but we are super excited for the new beginning ahead of us.
Put a volt meter on the trigger post of your relay and have your wife hit the key. It may be poor connection anywhere between the battery - bulkhead - fuse box - ignition switch connector - ignition switch - ignition switch connector - bulkhead - starter relay (including the bulkhead connector at the firewall); or a defective ignition switch. If you don't get the battery volt signal from the switch (at the relay), check the output of the switch (at the switch) when you hit Crank. If still nothing, make sure you have battery voltage going in. A poor connection somewhere between the battery & switch will often show voltage until you hit Crank; at which time the volts will drop to practically zero. Yea, yea, I know, a lot of work; but that's why most folks hate electrical issues.
I'd be looking st the NSS. I've seen them act up in weird ways. Easy to diagnose and change out as needed.
you can just bypass the NSS .....on Starter Relay Switch the Terminal G goes to the NSS....run a wire to ground ......bypassed
car!Fixed the purple beast. Best part is it was a free fix! Just a wire and couple of connectors.
We got our house all squared away in Missouri and moving truck rented for the 19th of June! These next couple weeks are going to go by way to fast!
Oh yea, I also got some more pecans the other day... these are the good pecans.
I was in Vegas over the long weekend, I was going to hit you up to see if you wanted help but figured you might be busy with the move. Glad you figured out your
car!
Well when the avalanche play the golden knights in the playoffs... you gotta go to the games! I'll be at Sunday as well. Unfortunately the better team lost but my wife was happy.
Gonna be a good series. I’m a Blackhawks fan in blues country. But when you get into Springfield you’ll be happy to see any hockey fans lol.
Heck yeah man! Have fun. Avs are due for another. Been since Ray Bourque came over lolI'll be at the game tonight as well! I had to make it to the games since it's rd 2 and how many chances will I get to do this. I also got tickets pretty cheap, compared to what they normally would be.
