You know next time im in vegas in going to want to see it!
There's always something happening at my house so when you're down here come on by! Maybe you will be here when I'm ripping the AC apart and can help me with it
Sure!I have scrubbed on this intake manifold and scrubbed and scrubbed. Still doesn't look as pretty as my other pieces, can it be painted too?
Thanks! Yours will too. Paint seems to stick to the porous aluminum just fine without any special prep. Except a good cleaning. Sounds like you got that covered!
Easier to clean teeth?
studying for a test?......just remember.... Pythagorean Theorem, the hypotenuse squared is equal to the sum of the squares of the other two sides.....and if that does not work ....the answer is C....
So...are we going to have to refer to you as Doctor?.....lol
good to see the progress, once you join the over 50 club it goes a lot slower LOL
Are you planning on doing the water pump and timing cover in orange too? I'd put a new water pump on while your in there. They are pretty dirt cheap.
Bonus points for getting battery tray out without breaking bolts!Battery tray is gross and so is the metal under it, took it out when u started scrubbing the engine bay
The top edge of the head between the valve cover and intake manifold needs paint too. A tip: sometimes it's easier to brush paint some areas instead of masking for spraying. Spray some paint into a paper funnel and catch it in a jar. Let it thicken for a while, un-covered. Get about a 3/4" soft brush and go at it. (Actually, don't cover the paint tightly for several days, as the container can leak or break due to the propellant pressure still in the paint).
So far so good. However working in the defense industry we are deemed "crucial" workers by the government. Even though I'm an engineer, I cannot work from home, due to a horrible, stupid, short-sighted IT department. And cheap-*** bosses. They won't lay us off either. So I'm going in to the manufacturing area every day. We are being treated like "The Expendables". Can't quit the job, because then I can't get unemployment, and even worse my health insurance disappears. I think I'll have to be extremely lucky to not get very sick eventually.My friend! Hope things are going well with you and hope you're staying healthy!
