Johnny Dart
Hmm.. Ok.
Whys the long bolt in that hole? Just trying to clean up the threads?
Ah, gotcha!
You can take a spare bolt and file or grind flats on a couple or more sides and use it like a tap or thread chaser.
In a pinch, use a hammer to flatten one or two places (but don't expect the threads to last past the next disassembly).
The problem is having it 1 side in the hole shows the threads and the other side still is smooth and flush due to old screw still being in there. I just dont want to go up another drill bit size and risk blowing the entire hole out and having to go to a larger bolt size.
That's definitely a challenge. Have you got a couple picks to try and spin out the remnant? A tap may just catch and drive the left over bit further into the hole.. Don't want to damage those windings.
I've been using an itty bitty flat head and just have not had any luck getting it out with that yet. I'll try it a little more after I get the ac bolted up. Sucks putting this thing back in as it's not even working anyways
LOL, then why bother? Use it for a core and get a new one. They're cheap (ish)!
Well my compressor works, and the clutch on the compressor. It just doesn't blow cold air lol
That's not your vacuum advance, its for your pcv valve.
Get in sit down and hold on, because you are in for some more fun.
Some valve covers have knock outs, I believe the MP covers you have to drill out. Then find the right size grommet, and pcv valve. Have fun with that.
Yes I read the carb manual and figured that out lol. Vacuum advance comes from the distributor
What more fun am I in for? Lol. I'm looking for a breather cap with a pcv port on it now I feel like it's so close to being able to start up and hopefully not blow up
