Phreakish
I think the oreillys only has a push on one though. Idk if that will work
O'Reilly and autozone both used to carry the twist in ones.. At least 15 years ago when I worked for them, LOL.
I would tell you, but unfortunately you wouldn't listen.
I got to stay off your posts.
PS: Those are for a breather and oil cap.
Go back to post 1300 and you'll see in the pics of other engines you posted, typically there's a pcv on one cover and a breather in the other. The oil filler is in addition to those two ports so I think you need to drill your cover that has the fill cap..
one way to find out - see if you can knock it out, use a socket or something as close to the size as possible so you don't dimple the top.
Chrome Breather & PCV Caps for Mopar Performance Valve Covers Small & Big Block | eBay
these give you want you want with a bolt on....but I dont like the price....
Justin, I have the same covers on my 360 and didn’t knock out the other plugs but you will need to screw on the small baffle plate to inside of the PCV side. The motor will suck engine oil in if you don’t and it will smoke from the tail pipes. Just speaking on past experience
Look at those 52yr old factory valve covers just sitting there ready to bolt on in all their glory. What did they ever do to you ? No bs aftermarket caps, breathers,grommets, etc to hunt down. No drilling, no measuring, no smacking, nothing. Nothing, but bolt on and go racing MaMopar badassness !!!
I know, you're still learning. You'll learn.
PS: Do you want to sell those old things ?
They can't be worth all that much after getting kicked to the curb.
Nice tennis shoes.........
I looked for baffle but couldn’t find one, but you figured it out. Looking good
