Tomorrow is D day...........lol
I should stop taking things back off then right?!
is that the same stuff you use at work?Got some new jb steel reinforced weld coated those tabs all up and filled in the middle.
It is your show....lol
Itty bitty my ***! I've had several crowns. They use the same gun I use to glue quarter panels on and fix fiberglass with. Tastes the same too. LOLSomething like that... except I have little itty bitty instruments to apply it with. This **** just came it on smear it with the finger and call it a day
tap tap tap grind grind grind. Should have been a dentist instead. lolThat's funny! You are correct though, most of the dental materials taste like crap. I try to rinse all my patients mouths out real fast right after I put anything in there that way they dont have the nasty taste for to long.
10-4. Screw them baffles. HahWell dentists during every recession get crushed financially if they dont have a tip top running business. Most offices have 70% overhead which is way to much. Right now I know tons of dentists struggling, but it should only be temporary.
Now about my damn fuel line haha. Jk. I'll go get the correct fitting in the am and get this pretty line on there so we can start and time this sucker tomorrow!
Just the right amount of shrapnel to get you a stroker.I got the baffles installed! It's going to be slow pouring when filling her up with oils
Nothing wrong with a 360. Those 340 valve covers will bolt right on.They are all screwed in with gasket maker on the threads. Hopefully they dont cause me to get a stroker, cuz then I'd have to do a 360
Hey Doc. Do ya know what makes the 340 valve cover special?
That's about it.Not really. I know they have specific wire holders and such for specific years and that's about it
It helps the wires clear the choke linkage for the 4 bbl carb.That's about it.
Yowza, progress! Looks good, maybe take it out for a spin tomorrow?
