Adapter purchased. Line installed 50%. Trying to figure out clamp situation from fuel filter to carb with the steel braided line as I only got 2 fancy ones with the steel braided line kit.
Doesn't look as nice as this! I need a longer stud for the carb/air filter though. Tomorrow all I have to do is drop in the radiator (2 minutes), yank that mechanical choke wire out of the grommet, install battery and attach the exhaust to the header collectors.
I also got some wire loom to clean up the wires on the firewall.
I don't think that Monster will give you the octane boost you might need for the engine - just saying
Great job it sounds awesome and ready to rumble and have fun
damn Im jealous
Wish I had a 70 aarcuda .........
we still got some final tuning up to do.....had to compromise on the initial timing to keep the total around 35.....He has an electronic distributor that was made by mallory for MP....I have a few of those and going to install one those fbo iginiton plates in it and then swap it out with his....then get the timing set and let him drive it around and see how it runs....
otherwise it is a very nice sounding 340....also most some as fast as a 360...lol......
Is your cable to the transmission adjusted properly?
Follow Lokar's instructions. But I found that even if you do, there may be fine adjustments needed later.Should I loosen it? I tightened it and the car didnt want to move at all without really giving it some gas.
I did realize the back piece of the lockdown cable wasnt seated all the way. So maybe it does just need to loosened a little bit now.
It sounds really really good though...
Follow Lokar's instructions. But I found that even if you do, there may fine adjustments needed later.
