Those are 340 specific too. Kind of a big deal.I was just kidding you. The best thing for you to do is keep them. Actually, clean them up and put them back on your motor.
Saw this coming 3 pages ago. Cut your loses while you can.
Clean these puppies up, and give them a coat of paint.
Bolt them on, and be done with it. No harm no foul.
Let me check my inventory.....we might be able to work out a swap....as I dont use the baffles on the race car...
I would not go that route. What happens when the glued peace comes out?
Got some new jb steel reinforced weld coated those tabs all up and filled in the middle. I'll drill and tap them tomorrow.
If you are going to use those covers I would use other side where the punch out plug is now. Just use that side with the broken tabs for oil fill cap. Make sure there is no loose pieces ready to break the rest of the way off into engine.
I just found what I used last time I installed baffles. These screws: Stainless Steel Thread-Locking Button Head Hex Drive Screws M5 x 0.8 mm, 8 mm Long. You will need a 4.2 mm drill, and a M5 x 0.8 tap to install them. They worked great, and are highly unlikely to loosen and fall out.
That should work fine. Back in the day I had a 64 Fairlane with a straight six in it, with a cracked block. I wire brushed the block, slobbered on some JB, and drove it for several more years before I sold it.
