Splitting hairs but get rid of the wing nut. O-ring and a regular nut. Push down on the lid a little while tightening.
Purple power or oil eater is great for oil. On porous blocks, @Bodyperson is right: solvents. A scrub brush helps too.
The speedo sender should have an O ring and a lip seal on the speedo pinion. Are you leaking from the sender or from where the cable connects?
Most autozones I've been to carry the thicker dual plane (two ovals) gaskets in the performance and chrome aisle, but ymmv, it's a regional thing.
Edelbrock Carburetor Spacers 8724
I got a punch that belongs to you was in bucket....bring it by tomorrow....
Be careful with the stud being too tall. I measured mine with clay on my GTS with the 499" stroker and looked to have plenty of room. My first time nailing it I have a wing nut dent in the middle of my beautiful hood. Joe
Ya know, that stuff will decay your teeth.
Lacquer thinner and floor dry. Hose it down with the thinner and grind the floor dry into it with some elbow grease. Might want to wear a glove.
Karen ? Really ? Thanks Richard !!!!
All depends on the motor mounts. Not so likely with spool type. Mount broke in my fury, noticed it when the hood lifted.
This made me lol. Thats nicer than the name my wife called me today haha.
Really though I do appreciate the input, I'm just like you said... deaf and a dick sometimes ;)
Doc, there's a hold down bracket for the speedometer gear housing. It looks like this. The two side prongs fit into the slots to hold it down.
Hi there. I haven't read all 74 threads but is that the original color? What's the code? Thanks a lot.
You took it back apart?
Very good chance you tore the o-ring during install.
Saw this on fb and thought it fit me and my welding perfectly!
Bring that O-ring to a rubber supply/hydraulic shop they might have one like it.
Pull your cable off the speedo adapter. Then with a robertson screwdriver you check that gears are engaged.
Easier to install with cable nut loose.
