Dartsun
Mopar Dude
Brake lines aren’t to bad til you gotta get the front passenger one lol. I always liked having a nice flaring tool makes world of difference.
Yeah, ain't making double flare brake lines fun? Not! Anyhow, with all the above suggestions I have another that's helped me over the years = a little brake fluid where the cone on the tool meets the line/area to be flared, sort of just helps a bit if for some reason the cone tries to turn as you're crimping, allows it to turn with the crimp versus not turning and putting a flat crimp in the double flare, which of course means "cut it off and start over".
cool, never too early to teach the kids how to pillage and plunderI'll give this a try with the many other suggestions in a bit when I start working on the car. Right now I'm hanging with the kiddos. Also I'm watching Vikings, its a great show if you guys are looking for a good one to watch during quarantine
Bummer dealstupid flare tool broke....
Bummer deal
Much like Clint Eastwood said, a man's gotta know his limitations. Me, I tried doing sharp bends to do the brake lines, and wound up with an exceptional solution just using my phone. Hello, is this In-Line Tube? Yes, please send me a full set of brake and fuel lines for a 69 Dart. Four days later the big box on the front porch is dancing around, waiting for its turn to attend the party.
Yea the jam nut got stuck and I tried loosening it and the dang bolt started bending. Well let's see what they say at Oreillys.
Your solution is about 100 more than I spent, plus I'm learning how to do a new job... if I fail out of dental school I could always just get a job as a mechanic lol.
Edit- your solution was also much easier than what I'm doing haha
My brake lines are all bent, just need to make some flares on the rear lines.... each line is left with a couple inches of slack at the end to account for multiple flare attempts. They follow the original lines about 95% as I made a couple small tweaks to the routing in certain spots, that way I didnt have to make as many of the little "Z-shaped" bends.
I'll bet you will be first in your class! Your wife and kids will be proud of you no matter what you do and I think you got a 5 star rating from this group. Plus wait till you learn about uv light hardening epoxy nothing will stop you. lol
I've been at inline tube they make some great ss (steel also) lines and my hands don't hurt afterwards. Also they'll make about anything you need. Nice people.Much like Clint Eastwood said, a man's gotta know his limitations. Me, I tried doing sharp bends to do the brake lines, and wound up with an exceptional solution just using my phone. Hello, is this In-Line Tube? Yes, please send me a full set of brake and fuel lines for a 69 Dart. Four days later the big box on the front porch is dancing around, waiting for its turn to attend the party.
i got a pair of those a couple years ago, wish i'd done 20 years ago. great for making adjustments
Do you have drum/drum or disc/drum brakes?
Braking all the flaring tools in town. When I said the passenger side brake line was a fun one I should’ve specified installing it. Your almost done flaring the idea of getting the 20” pre flared is what I do for my rear housings.2nd flare tool down!!! Little nipple broke... ill get another tomorrow. I only have 1 line left to put flares on then ill start installing everything and hope I don't have leaky brakes. I'm actually thinking of buying another 20in pre-made line because I don't like one of the flares on the line to the rear drivers side.
or buy the prebent lines...lol
wow, either those things are made out of potmetal, or you must be real fun doing a root canal2nd flare tool down!!! Little nipple broke... ill get another tomorrow.
Chamfer the tube before the initial flare operation. It gives the tool a little head start.
i've had the same style set for over 30 years
It amazes me how the dental process mimics autobody repair or vise versa. We grind and glue. Pretty sure we use the same tools. And the chemicals taste the same. lolI'm telling you dentistry is much easier for me than some of this stuff lol. But I also think the new tools are not close to as good of quality as the old stuff
