Is your Fuel tank vented? Could it be vapor locked? Do you have a tight sealed fuel cap? Sorry for all the questions
Ever thought that the ECU is getting overheated?.....next time it shuts off on you....
Do you have a spare ecu?
Go to the basics if it will not restart, check fuel and spark. Grab it by the ears and look down the belly of the beast (down the carb ) pull the throttle lever back a couple of times and see if it's squirting fuel. If it is than pull the coil wire off hold it ( not your hand ) about 1/4 to 1/2 inch from the intake manifold or a bracket. don't use the valve cover, and see if you have spark.
Also I personally keep AAA just in case. You can get the 100 mile free towing deal for a little over $100.00 a year.
Wife has caa, if i need a tow, she calls.
Im assuming your cap/rotor is fairly new?
Had a rotor do that. vapour lock in fuel system can be addressed with an electric fuel pump and a return line to gas tank.
Start at beginning of thread, theres lots!When you get a minute post a under hood pic.
Do one of the pass side rear please.It looks the same as this picture from a couple weeks ago. I literally have not done anything on the car since washing and polishing it.
Been doing school stuff and have finals starting tomorrow.
I didnt have this problem until this year after doing the cam and stuff. Last year it was fine, would just overheat.. Fuel injection, thats pretty expensive right?
Wasn't cheap! LOL. I think I figured I spent around $1800 all in with an in tank pump. I bet it could be done a couple hundred cheaper today.
If it was fuel related, I'd expect it to quit running if you're idling or in stop and go, but not on the highway. What were you doing when it quit? When it happens, a quick test for spark will help determine if it's something in the ignition. How hot is the coil when the engine quits? If it's screaming hot, might be a clue.
I'd be tempted to try 15-20 mins on the highway to see if it happens there at all. If it does, I doubt it's fuel. The 215 has wide shoulders on the east side. Makes for a nice spot to troubleshoot if you can stop under and overpass...
I'd also try to find out why your ignition buzzes when it's on - I think @70aarcuda is probably on to something there.
No way. A Mopar is to driven hard and put away wet and it'll still kick *** the next time you ask it to.Maybe @kursplat was right and the purple car is going to be a trailer queen... everytime I try to drive it lately the damn thing dies on me.
