I have 68 dart. It was sitting in a guys yard for 15 years just rotting. So now that the car is painted and put together, i try to test drive it and I noticed that only one of the green turn signal on the dash lights up, and nothing on the dash works. The tach that I have mounted on the steering wheel lights up. The brake lights work, headlights, high beams, cabin light.
So no turn signals, dash gauges haven't moved but, alternator gauge kinda moves a little, and only the left turn signal lights up green.
I have steering wheel column out of a 73 duster I believe? If that helps. It has a key ignition mounted into it.
I know electrical is a bit of a pain but if someone can point me in the right direction that would be awesome
