Ok, let me see if I can answer your questions.
2. Yes, to measure compressed thickness of your head gasket, the most accurate way is to get one like you plan to use and torque it down on the engine, then take it off and measure the thickness and diameter of the fire ring. (or save a used one if you have one just like that has already been compressed).
3. For volume above the piston at TDC; If you have flat tops, you can just measure how far down the piston is at TDC, and the diameter of the cylinder bore and calculate from there.
You can also use the water method with the cover plate as described in the compression check thread.
You could also try to do both to check for accuracy, but they should come out the same if done correctly.
4. I don't get how your bore is 3.95 when is should be 3.40, and you say that it's smaller. Isn't 3.95" bigger than 3.40"?
5. I usually just use the stock stroke numbers from the books to calculate swept volume, but if you don't think that your engine is "to the book" then find BDC and measure the depth of the piston in the bore at TDC & BDC, then take the difference.
6. I recommend the liquid method if you can't measure it easily. (It's much easier if it makes a perfect cylinder and no other "variations" to calculate with bore and depth). The liquid method accounts for everything in your engine, but is not practical to measure at BDC (the water tends to leak when you are trying to fill this much volume). You can just use the bore diameter that you measure at the top, I don't think a little wear will affect the results that much.
2-I plan to use a cheap fel-pro head gasket on this engine, ( just to get it running ) Can I use Kids formula above and still be Ok?
Quote from Kid: Felpro is .037 thick for both 3.4 and 3.510 bore gaskets
Can you explain....why does he mention two different size bore gaskets?
Arent these steel gaskets no longer avail.....
Quote from kid: stock steel "shim" gasket is .021 thick for both 3.4 and 3.510 bore
I plan to ultimately use a Victor Reinz head gasket. This is what has been recommended to me, what is your opinion on this gasket, I have been told it will handle up to 12.1 static compression ratio.
Not sure why this is desirable for what I am doing but what do I know and my thinking is that it must just be a better head gasket. Maybe its overkill for my application.
3- I have measured ( see attached pictures )
Cylinder bore diam is 3.395 and a deck height of approx .155 thou.
I say approx cause measuring in this fashion is not the way to do it, clearly with even the slightest inclination of the tool the measurements can jump anywhere from .140-.170 thou.
I plan to get a proper depth gauge from e-bay and measure this correctly. At this point though I am certain that .155 thousands is pretty darn close.
Can you explain why the small cylinder bore, I have checked and double checked. I am certain that is where it is at. Is this common?
5- What are the stock stroke numbers, where would I find this info. Id like to see a listing, was this number changed at all for 225s or did it remain the same even through the hydraulics?
Isnt it true that I will need to decide what to do with my cylinder head before proceeding any further. Isnt it true that oversize valves will affect the final outcome of the measured CCs ? What is the usual volume of these heads. Can we use this just so that you and I can continue moving forward on this whilst I decide what I am going to do?
I would like to know how much slight variances within these numbers will change things. For instance lets say engine started out with a 3.40 slug and was overbored 60 thousands. I am assuming that means we now have a 3.46 bore diam. ( or is that 3.460) Please tell me how to display the correct figure.
So lets say we have that 3.46 ( or 3.460 ) bore diam but have the same deck clearance of .155 thous. Combine that with a standard slant combustion chamber volume of _____
Sorry I do not know what this is but it seems to me I remember reading 55 or 65 CCs ?
How much will that overbore mean to the compression ratio. Overbore would decrease the compression ratio from what I have read and that does make perfect sense to me but Id like to know how much of a difference that will make.
Same scenario with maybe a taller deck height, lets say we have a standard 3.4 bore diam, but instead of .155 deck height we are at the extreme of .210 below deck. How much will that effect compression ratio assuming we are safe to use Kids compressed Fel-Pro head gasket thickness of .37 thous. thick.
Hope you get where I am coming from and the reason for all the questions is because the engine that I care about at this point is in my truck in the garage, freshly re-built but internal statistics un-known. I plan to be an expert on all of this after completing this engine and will use what I have learned here to optimize the engine I care about.
One last thing: Would it be possible to do all of this sort of work with the head on the engine? Too be honest I am absolutely shocked at the small amount of piston overlap that a slant has.
The engine that is in my restored truck has some issues, I was finding TDC using the screwdriver in the hole method ( thru the sparkplug hole and feeling for when it come up and dropped )
I know now that a B.S way of doing it. The overlap is so mimimal ( maybe they are not all the same ? ) I do not see how any of these set-up procedures can be done....even degreeing a cam whilst the engine has its head on.
What can you say about all of this?
Thank-you for your time this weekend
