MOPAROFFICIAL
Oogliboogli
Exactly.what's dead on.
It'll like what it likes and that may be straight up,2 adv, 3 retard, 4 adv..whatever he finds out it likes.
I believe they are machined to match. Flow may be an issue but the Super Sniper is rated to 700 hp aspirated and 1250 hp boosted. So I thought it was enoughThat EFI is choking your the flow capabilities of of your ported heads.
I ran a Holley 950 cfm carb on my 512 and I believe it would have taken more and that was with a set of old school ported iron heads.
How about your intake was it port matched to your TF heads?
That’s a tiny cam for a 512 engine. As stated too small of fi system also. Degree the cam at least. I doubt that ur engine even pulls to 5500. It’s a torque monster for sure. A 1000 4150 style carb will pick it up like u won’t believe. My 470 gained 2.5 tenths going from a 750 to a 1000. Kim
what was the trap MPH on the 12.3 runs? what about the 60ft times?
is your car setup to be a drag car or is it just a street car?
Kent, let me address the question no one has. You mention the cam is on a 110 LAS. That cannot be changed without either regrinding the camshaft or replacing it with another one with a wider LSA. The LSA is ground into the camshaft. And you're correct on more than one count. Larger cubic engines sometimes respond better to wider LSAs and especially with power adders like nitrous. It's not an end all be all though. What I would do is do a search for @crackedback 's "Hillbilly timing tape" and do that to your balancer......unless it's already marked and it should be a good one on a 512, so you may not need that. Find TDC with a piston stop and verify the marks are correct. Then you can actually check the camshaft numbers without pulling much more than the radiator and pulleys.
I have a sfi certified damper with timing marks from 10 to 0 to 50 degrees. I could find TDC with a piston stop. How would I then check the camshaft relative to the crankshaft? Regular degree wheel mounted to the crank? Would I pull the valve covers and check the lift of the valves/rockers and degree off of that. If I am on or off specs, then we have solved at least if the cam is ground correctly according to the cam card. Whether or not it is correct for the car is another whole story. Do I have that correct?
What is IC? a compression check is easy. I will do that this weekendBefore taking stuff apart maybe run a compression test first because it's relatively quick and easy. With your low-10 SCR and that cam I'd call it good if it cranks close to the 170-180ish neighborhood? Now if it cranks140s-150s then yeah maybe it's off and wants to be advanced a bit more. Otherwise...the cam's IC isn't your problem.
It could very well need more detailed tuning, BUT since you're judging it on track E.T. I kinda think it's gonna take some more camshaft to get you where you want to be...good luck!
what's dead on.
Sorry, Installed Centerline.What is IC? a compression check is easy. I will do that this weekend
I ordered a tdc tool and will check it next week when the tool arrives. No local auto parts store had one in stock
Printed out a couple of degree wheels from the Stock Photo above.
Printed them to the 7" size instead of the std 8" size so they fit nicely on the mopar dampers.
For checking cam events without opening up the front of the engine.
Can cut the center of the degree wheel out and just leave the outter numbers to temporarily paste on to the front damper.
There's a few heavy hitters involved with that build.Similar build........
Dyno Time Finally RESULTS IN
Even if the dyno results on that build are off(high) by 10%......... that would still leave plenty of power to run low 11’s in a Dart weighing in the 3500-3600lb range.
