Also if no one's mentioned it, the lash on the valve you are checking should be set to zero.
He did that. KimAlso if no one's mentioned it, the lash on the valve you are checking should be set to zero.
Looks like your valve timing events are coming in retarded instead of on the degrees you desire.
Can move to cylinder #5 and check the @.050 valve events there to see if they are the same as #1, or if it is an isolated cylinder thing.
He did that. Kim
I will do this tomorrow as I have a meeting to go to.Looks like your valve timing events are coming in retarded instead of on the degrees you desire.
I would think number 6 as it’s opposite in the firing order. KimI will do this tomorrow as I have a meeting to go to.
Do they open and close at the same time as #1?
In theory yes, but in real life...NOCam lobe lift x 1.5 ratio rockers = final lift.
If the timing events are truly that far off, you have a bigger problem somewhere in the valve train.Here is what I have found. I used the TDC tool and My TDC lines up correctly with the 0 on the Balancer/Dampener. When I measure the degrees at .050 tappet lift, (.075 spring retainer lift since I have 1.5 ratio rockers), I have the opening at 4.5* btdc and it should be 15*btdc as measured on the dampener. The closing mark at .050 tappet lift is at 57.5*ABDC not 51*. Thinking I may have a flattened lobe I checked the LIFT of the spring retainer. I got .492 on the intakes of cylinder 1 and 5, Should be .517 inch. Exhaust was .502, should be .537 on #1 cylinder. Also thinking that my dial gauge may be off I measured a drill bit with calipers at .481 and then measured the dial lift and it was bang on. I am confused by this. Wrong cam?
I finished checking the Lobe centerlines. I got 109* for the intake and 115* for the exhaust. With my checking without a degree wheel and taking all measurements off the balancer I think the measurements are pretty close for the centerlines. Would this make you comfortable leaving it as is?
Take the spark plugs out.I will redo all the numbers again tomorrow or Tuesday. Another thought or question. I have both rockers on. Turning the motor over is a big pain and I feel that there may be some spring tension or compression. It is about time for adjusting the valves. Would it be wiser to remove the rockers so that I could rotate the engine more easily? I would not want to remove the heads. I
Can then measure lift directly off the solid lifters. I have an adjustable rod that I can use if needed.
Thank you everyone for all the advice, help and encouragement.
I can take 7 of them out but one I have to remove headers and that requires undoing motor mounts and moving the motor. What about the rockers?Take the spark plugs out.
I would not remove the rockers.I can take 7 of them out but one I have to remove headers and that requires undoing motor mounts and moving the motor. What about the rockers?
Didn't think of that.I would not remove the rockers.
Rockers off and plugs in you will never rotate the engine as the compression has no way to escape the cylinders.
What the hell kind of headers do you have that you need to pull the header to get the plug out - that aint right.
I will try.with a little effort I'm sure you could get the last plug out.
I might take modifying a wrench
Dont mess with rockers - no need to.Didn't think of that.
TTI 2 inch. The #6 plug is a pain in the butt. How about just removing the 7 plugs and the left side rockers? OR Maybe I can back out and remove the adjuster bolt and then I could measure directly off the lifter/rod and bypass all the geometry/ratio etc.??
