Was second pull with a holley?
Tell him you want your avs and to tune it.
If that does not suit your horsepower goals, get a thermo quad and have him tune it on the dyno.
- New
- Add bookmark
- #226
SO all you did was change carbs and gained 20 hp at 5000. I see the horsepower is still climbing at 5200 on the second pull. You haven't reached maximum horsepower yet. Slap that dyno operator upside the head for me will ya!Well I'm back after another pull scheduled for Friday afternoon. Brought my heat gun with me. During engine warmup, discovered cylinder 7 only at about 387 *F. All others are in excess of 1000. Heat gun only goes to 1000. Turns out the spark plug wire was burned about in half by the headers. This was through heat sleave I have in place. Pull results are as follows.
True? I thought you were going to switch carbs this morning for today's pull.Last two pulls was with AVS. First pull was posted.
Ran carb yesterday with 600 holley and avs. AVS on last two pulls. Holley (first two pulls of the day) had better A/F numbers but room was cooler. Was more interested in pull with my carb this morning in cooler environment.True? I thought you were going to switch carbs this morning for today's pull.
Stock 1970 340 manifold.Also are you running a real 340 intake manifold ?
Was your dyno sheet on page 1 here with the Holley? And the latest dyno sheet with the AVS? Just making sure.Ran carb yesterday with 600 holley and avs. AVS on last two pulls. Holley (first two pulls of the day) had better A/F numbers but room was cooler. Was more interested in pull with my carb this morning in cooler environment.
All dyno sheets posted were with avs.Was your dyno sheet on page 1 here with the Holley? And the latest dyno sheet with the AVS? Just making sure.
And the power numbers follow the AFR around 4,000. Jumping around quite a bit.View attachment 1716142546
AFR appears to be jumping around a bit until 4000 rpm, when it finally settles in.
it looks to be calculated from BSFC and Air consumption. If so thats about as real as it gets.
That's what I said earlier. You can't get to maximum horsepower until you get there and then it starts falling off. Heck, there may be another 500+ rpm to go before that happens.What is with the 5200 rpm? The hp is still going up. Rev the dam thing up and see what it is producing.
It's running out of breath.What is with the 5200 rpm? The hp is still going up. Rev the dam thing up and see what it is producing.
What is ve%. Is that affected by A/F ratio?your ve% went way down so did your power
Now you're just wasting everybody's time including the Dynamo wizard. Set the timing total where it's supposed to be make sure your throttle is opening all the way, fire it up and rev it until it stops making more power. Once the power drops off. shut it down. Stop wasting everybody's time and your money. That motor can safely rev to 7500 if they built the bottom end correctly.Well could have gone better. Here are the latest results. Last pull.
