With any stock head and not just mopars, air flow and cylinder filling is less than optimal. That is why you want to squeeze what you do have as much as possible.
Saw your post on compression. What did I miss in my calc?Ok, I re read your post, missed it the first time. Straight edge is acceptable, I would have used a feeler gauge with it. I was a tool and die maker during my working years, so measure,measure,measure. See my above post on compress.
I know you are frustrated, its a long road but your going to get through this.
I question your dyno guy. Don’t you want to run your avs after you get this straightened out.
Your right. I am very frustrated. So much so I would rather start over on a different engine.
I think my dyno guy is OK but like said earlier, he should have installed cam. That is my fault for at the time did not know one hade to degree a cam. Not that it's very difficult but was involved. Likewise to cc combustion chamber. I enjoy learning new things.
I do want to run my AVS. Based on numbers, I see why he want to run smaller carb but think he is going do the wrong path.
Do you want to buy a cam???? At this point, to buy a ne cam is cheap for what I have in this engine.If you were to pull cam to double chk/degree, you may as well install a better suited cam/lifters. Sell the current one, someone will buy it and put that $$ towards new set. You might be out $100-150 ??
Just a thought. I wouldnt be content with current cam if it turns out that's all it needs is a cam swap.
Hi Jim. You got me thinking. Understand people intentionally vary cam timing to suit their needs. Am I understanding that correctly. If so and like you said the curve would change but never look like mine meaning something is totally wrong.A few degrees of cam timing will not give you that much deviation from a stock 340... There is either something totally broken or you need to try a different place to dyno it.
That cam should only maybe shift the stock 340 curve down in the RPM band just a little bit.. likely on the street you would not even notice it if you don't wind it out m
I can't live with myself knowing the curve looks tike it does.That cam should only maybe shift the stock 340 curve down in the RPM band just a little bit.. likely on the street you would not even notice it if you don't wind it out much.
I agree. If anything, the stock AVS is too small, not too large. Even for a stock 340.A smaller carb is just going to hurt more. Avs has 554 cfm and on a dual plane each cylinder only sees 277 cfm.
Everyone is hung up on the cam or Air/Fuel.... i would be dropping a different dist into it... I know the timing was checked but it almost seems like it's pulling a ton out for some reason.. which would leave it rich and the weird curve and all that. i'm rarely right though..
yeah... is it me or is this thread have a bad vibe? not the OP/topic just a lot of arguing and not much actual help other than theorizing... just my .02.. i'm having a meh day thoughBeat me to it by one minute! Something is wrong... everything about the mechanical build seems like it should be close to a stock 340.....
Yea and what do I know... all I have been doing is blocking for the last 3 months....
Oooh, that trucks gonna be a beaut!Yea and what do I know... all I have been doing is blocking for the last 3 months....
unless i missed it, you have a stock AVS no? those are rated at like 630cfmI do want to run my AVS. Based on numbers, I see why he want to run smaller carb but think he is going do the wrong path.
Funny you should ask. Just got off the phone with gear head friend from work. He is concerned about timing as well. The engine is making use of Prestolite dual point that Ray at Halifaxhops rebuilt for me. Do not know how much advance engine guy has dialed in at the moment but first on my list to ask when I see him again.Jawbone, i don't wanna read back again but don't think it was asked.. does your dyno guy run any type of MSD box or any type of electronic controls on his dyno? What dist setup did you use... this all looks like pulled timing..
that cam isn't bad enough to kill a motor that hard... and the carb would have to be a dominator set on kill to be that bad.
Hops knows his ****, but ignition timing would explain every issue you are having..... could be something there...Funny you should ask. Just got off the phone with gear head friend from work. He is concerned about timing as well. The engine is making use of Prestolite dual point that Ray at Halifaxhops rebuilt for me. Do not know how much advance engine guy has dialed in at the moment but first on my list to ask when I see him again.
Prestolite dual point rebuilt and setup by Halifaxhops.tell us about your ignition and distributor setup......
What did you set the initial timing at?Prestolite dual point rebuilt and setup by Halifaxhops.
