j par
Well-hung Member
I was wondering if anybody uses 100LL av gas and what there experiences were/are ?
I have and have never had an issue with it. If your trying to run it in a car with cats though......no bueno.
I usually mix it 70/30 with 93 octane and have had great experiences.
Only problem is that if your out on a long trip, you have to plan ahead and either know where to buy more, or bring some with you.
Since I like to go on long cruises, I have been using Race-Gas for the last 3 years, and it works awesome. Never have any detonation problems and it mixes to whatever octane rating you desire, within their range.
It's about the same price as mixing Av Gas. I mix one 32 ounce can with 8-9 gallons of 93 pump gas and get 101 octane. It even smells just like racing fuel.
RACE GAS | Racing Fuel Concentrate
I have gone through at least 20 cans of this stuff and it's bullet proof.
Have you bought an airplane?
AV gas has additives in it that can be bad for your car. There are stabilizers and such in it that allows it to perform at altitude. Read up on it. We've argued this point before and I was totally lambasted, but it's true. You don't need to run AV gas in your car.
Blowing up cars using 100LL, that's funny.
Do you get blue dye accumulation around the bowl vents? Now I really wanna use it!Used to run 1/4 avgas to regular unleaded in the 440 cross ram 67 Charger I had. No problems what so ever and ran the best with it. 100 LL still has 5 times the amount of lead that regular leaded fuel used to have, so it will accumulate on plugs. Stay's fresh much longer and if there is a fuel leak the blue dye helps in tracing it
By the way, happy birthday.Do you get blue dye accumulation around the bowl vents? Now I really wanna use it!
Gosh, thanks. My ex wife and daughter hadn't even mentioned it.By the way, happy birthday.
