Sirsmiley9
I’m removing my transmission and it seems to pull it out with the motor it will run into a part of the chassis that forms the transmission tunnel. It’s a a 76 duster with a floor shifter a/833 with od in
Damn those transmissions are heavy! (duty) LOLI am not a fan of pulling a transmission out with the engine, too many possible ways to dent the engine bay.
I drop the trans out the bottom then pull the engine.
Remove the shifter, handle and linkage, then the rear cross member.
I made a support jig to support A-230 3-speeds with my jack, it works awesome.
Two bolts and three nuts????I’m removing my transmission and it seems to pull it out with the motor it will run into a part of the chassis that forms the transmission tunnel. It’s a a 76 duster with a floor shifter a/833 with od in
