TrailBeast
AKA Mopars4us on Youtube
So I drive this 73 Dart everywhere I go, and that is a LOT because I have to go onsite for most of my work.
Then on weekends I drive it just for the fun of it, so I need to keep it reasonable for daily drivability and fuel economy for now.
I seem to be at kind of a stand still on the engine because of this limitation.
It is a stock bottom end 318 but I have already added,
600 CFM Eddie carb with full size chrome air cleaner
Dual plane Performer intake
1 5/8 tube aluminized headers
2 1/2 inch aluminized dual exhaust (X piped)
Flowmaster 40's
Mini starter
HEI ignition
8 mm Accel yellow silicone wires
NGK V power plugs
Fabricated aluminum valve covers with chrome caps
Fully automatic electric cooling (keeps it under 210 on hot days)
26 inch two row radiator
190 thermostat
My future plans are to pick up an LA360 and have the heads done and milled to run on the 318 while I take (probably months) to do the 360 bottom end, then drop the 360 shortblock in and put the heads back on it.
(Obviously I'll be changing the flexplate and converter at the same time)
I already have a small pile of stuff I can't use yet till the 360 goes in.
(MP cam and lifters, double roller set, and a few other things)
The car runs great, and is extremely reliable the way it is, but can you all think of anything else I can do for performance besides tearing into the bottom end and limiting the fuel I can run or the fuel mileage?
I get about 14 mpg as it is now.
Thanks
Flowmaster 40's
Mini starter
HEI ignition
NGK V power plugs
190 thermostat
Thanks
