Cudafacthackjob with his typical drive by with the Red X and no explanation.
Yes it is! With this Ford 9" I am building to go under Vixen for example. I did the same with it that I do with any other rear axle starting from scratch. When locating the perches, I get the location and width correct and then rotate the housing so the pinion ends up 5 degrees nose down and make my welds. Done many like that and they turn out spot on every time.Yup, it's trial and error at best once parts start getting swapped. I run non-stock leaf springs and have a 3.91 rear end, so it takes an extra 3 degrees down from theoretical 'right' to run smooth uphill. Then I added assassin bars, and had to reset once again LOL.
I think it's more important for people to understand why the angle across the joint needs to be equal in the first place, helps visualize what's going on. In this day and age, I think folks would benefit from trying to stick a camera or phone under the car to take a video of the axle wrap during a quick drive. With some creativity, it could be used to really dial-in what's required.
Things can change when you set you're lard *** in the seat, or mine.I get it. My point was that he "probably" needs something somewhere in between granny's church goer and a prostock. I've never in my life set drive line angles at rest......well......you have to, but you understand what I'm saying. You have to guesstimate based on acceleration. Setting it at rest will result in a negative drive line angle under acceleration and that's a sure fire way to get a vibration.
Big time. If you've ever seen a rear end hard launch with a go pro or some such, you can see just how much the rear axle rolls up. It's pretty dramatic. Even with a warmed up street car, it's more than you might realize.Things can change when you set you're lard *** in the seat, or mine.
I used the Tremec app on my phone, hoping they know what they are doing.
You do need to be careful (as I'm sure that most on here could figure out) not to have your phones buttons affecting your readings.
https://www.tremec.com/menu/tremec-toolbox-app/
Maybe I should have explained it a little more.5 down relative the engine, or relative the ground? I think a lot of the confusion comes from exactly how the angle is measured.
The rear U-joint should be 5-7 degs nose down with you in the drivers seat
The angle should be measured on the damper at the crank centerline
Tell us how it's done pal, instead of doing the drive by X.What? 5-7 degrees down is INSANE for the street. That's a race car only scenario. Is that better than just a red "X"? But now I have to listen to your opinion about my opinion...
5 down relative to the ground. This is with the rear axle on jack stands, flipped upside down.....so essentially it's 5 degrees "UP" but of course ends up 5 down since it is flipped back upright and installed.5 down relative the engine, or relative the ground? I think a lot of the confusion comes from exactly how the angle is measured.
I couldn't have written it any better.If I remember right angle should be same as pinion angle. (Opposite to be more accurate.) Race typically 2°-3° Street 5°-7° This is final starting points with driver in seat. "Starting point" being the important factor. Each car is a little different. The shorter the wheelbase typically means slightly higher angle required.
No rule is ever 100%. So share any discoveries you find.
That's how I've always done it. Make the pinon parallel with the trans/engine centerline and rotated it down 2-4*. Easy peezy.I dunno, A body has the perches level and the pinion pointing up 5*.
If the trans output is at 0*, regardless of position with the ground, the pinion should be in the 2-4* down position to account for roll up under cruise.
Anymore than 4* usually starts to strain the U-joints
JMO and this
Ford used balancers like that on drive shafts for decades.Has anyone ever attempted a harmonic type balancer for a driveshaft? This of course wouldn't replace having a balanced shaft. But a balanced shaft is still static. It certainly doesn't take into account thermo, or lateral stresses. Would probably be more effective for high speed applications.
Remember. There are no dumb ideas. Just dumb people posting them!
I know they were big on split driveshafts. Never seen a balancer on a single shaft. (But that just demonstrates my lack of on hands experience with Fords.)Ford used balancers like that on drive shafts for decades.
Just to be clear what my situation is. The car is on a 2 post lift that is adjusted so that the flat bottom of the rocker panels is flat (0 degrees). The back of the car is supported on tall jack stands under the rear housing tubes so that all the weight of the back of the car is on the springs. When in this position, the trans is also at 0 degrees and for reasons that are too involved to go into here it would be difficult to change. In this position the pinion angle is 3 degrees down. The driveshaft is 5 degrees down from the trans to the rear end. This means that overall the pinion is 3 degrees out of parallel with the trans. Therefore the angle between the trans and the driveshaft is 5 degrees down and at the pinion and driveshaft it is 8 degrees up.
After reading all these posts and looking at the diagrams and going to links to video explanations of how this should work, it seems that what should happen is to shim the pinion up 3 degrees so that the driveshaft angles are approximately 2 degrees up and 2 degrees down and the transmission shaft and the pinion are parallel. I throw this out there hoping to get some specific input on WHY this ISN'T what I want to do.
The only thing that I haven't been able to factor in is how much the pinion angle would change driving on a flat road at 60 mph. If it matters the leaf springs are new 6 leaf ESPO springs.
Unrelated to my situation, does anybody know what the angle of the original transmission is on one of these cars from the factory? I'm trying to figure out what people are saying regarding the pinion angle from the factory and how this translates to all the driveline angles from the factory.
Thanks for all the input
