j par
Well-hung Member
I can see it's some kind of divider plate down in the secondary witch does me no good...
@yellow rose remember this suggestion and conversation? They sent me the wrong stuff! LOL just when I was giving one of those kids on the tech line some credit.. they sent me four of these old divider plates that go down in the secondaries... Absolutely no use.. I'll call again tomorrow morning and see if I can get them to send the right thing...
I took a quick note on the Edelbrocks. the 500 Edelbrock specifically tuned for dual quads.. and the same 500 Edelbrock as a standalone..Unbelieveable. Just unreal.
Dude, you have the bad luck of myself.
Drill yours, you got more coming he says LOL...Unbelieveable. Just unreal.
It's about all I have to go off of and making comparisons. Edelbrock has it down to a science where things are almost infinitely adjustable. I'm very much limited to what's made for the street demon. Of course you know I learned all of this afterwards..after the rod size is taken into account, looks like the dual quad Ede’s are about 6 numbers leaner on the primary side.
With pinning the air bleeds, no idea if there are also other calibration changes not reflected in the jet/rod sizes.
Yes those would have been nice and I could have just put them on there hook them up and off I went...SLAYER SERIES CARBURETOR 450 CFM VS GAS TUNNEL RAM PAIR Front & Rear Carburetors | eBay
Personally, I wouldn’t want the choke...... so I’d get two “front” carbs.
Do you really think the two inch open spacers are hurting?..I’m not saying you intentionally bought the wrong carbs.
It’s what you said vs what I “hear”.
You said: “I’m buying two street Demon 625’s for my TR and I’m going to put 2” open spacers under them”.
It should be great!!
I “heard” : “I’m buying two carbs that aren’t really suited for my TR, and I’m going to make matters worse by using 2” open spacers under them”.
It should be a real challenge!!
when he posted that thread "talk me out of these", we told him buy holleys. He said "couldn't afford them".... but, as usual, cost about the same. He could have been shifting gears and kicking rears, but instead, he's "bogged" down.So, you’re at $676...... so far.
Those QFT carbs would have been $30 more....... and use low cost, readily available Holley tuning parts....... and are designed for exactly how you want to use them.
They are Holleys...when he posted that thread "talk me out of these", we told him buy holleys. He said "couldn't afford them".... but, as usual, cost about the same. He could have been shifting gears and kicking rears, but instead, he's "bogged" down.
yeah...…… good.They are Holleys...
We went over this before correct? I'm not what you call Cookie cutter material..So, you’re at $676...... so far.
It is shifting gears and kicking rears... Honestly could just be a little bit more of my combination then the carburetors fault. It's still a pretty rowdy cam with the gears that I have.. like I said when it's on it's on! Generally when you're racing you don't let off cruise for a while and then try to stomp it LOL..when he posted that thread "talk me out of these", we told him buy holleys. He said "couldn't afford them".... but, as usual, cost about the same. He could have been shifting gears and kicking rears, but instead, he's "bogged" down.
my mind always goes to those two huge cross rams they put on the Big blocks back when...I’m not there seeing how things are playing out.
A lot of is “feeling” how the motor behaves, and when it doesn’t certain things in relation to throttle movement.
But if there are tip in issues........ask yourself....... where is the squirter....... and where is the combustion chamber(you know, the place where the rich/lean thing happens)?
And....... what’s in between them?
If the squirter was 12” farther away from the chamber....... would you expect the problem to get better or worse?
How about 24” farther away?
If the squirters discharged directly into the intake port of the head, right behind the valve...... better or worse?
Thats not even talking about the “accumulator effect” of having all that plenum volume dampening the signal to the carb.
But....... it also may not matter at all on that combo.
As with most everything in this hobby..... there’s only one way to know for sure.
If I roll into it it's fine... I can definitely finesse it a little bit especially when I know it's there... Kind of like I was saying the doctor says if it hurts when you do that don't do that LOL..What about if you “roll into it” instead of punch it?
Maybe all that has to happen is a little more drivers finesse.
Sounds like they’re pretty close.
I was just thinking... around here they have a lot of 4x4 mud bogs. I bet your car would do good in a mud bog...If I roll into it it's fine... I can definitely finesse it a little bit especially when I know it's there... Kind of like I was saying the doctor says if it hurts when you do that don't do that LOL..
