Raleigh Rocket
Shake 'n' Bake!
Should I get this setup or would I be better off with a Hurricane or a Clifford unit? For a street/strip car, assume money is no object.
2: Dont start comparing doing a V8 swap because if you do, you find out its in a lot of cases that swapping in a v8 is cheaper.
Do you want a fast slant,or a slow v8,$5,000 will get you either.What are your goals?If you want a daily driver that runs 13s go v8.I personally would go with a high 14 second slant car that would beat alot of the v8 guys that think there car is a 13 second car.MY opinion.Guzzi Mark
You don't know me from Adam, I don't know you from Jack. Even so, your opinion is worth a golden brick to me. I've seen the wake of broken hearts and bowtie-shaped puddles of tears that Mad Max slant 6 car leaves behind.
Slant 6 it is.
