First thing to try is one of the two
1.....Use a clip lead and hook battery power direct to the coil+ and see if it starts or you have spark
2....Or put your voltmeter on the coil +. Turn the key to run. You should have anywhere from 5--11 V
Then crank the starter WITH THE KEY and watch the meter while cranking. You should see 10.5 V or HIGHER when cranking
If not, as above, the "bypass" circuit known as IGN2
Another thing.....
If you have HIGHER than indicated with the key in "run" above, this means that the ECU is either bad or not grounded, or the coil is bad. Unbolt the ECU. Scrape the firewall and flange of the ECU clean and re--mount tight. use star lock washers. It MUST be tight and GROUNDED. MUST
Remove the distributor connector. "Work" it in / out several times to scrub the terminals.
Hook the distributor connector to your meter, set for low AC that's right AC volts. Crank the engine. It should generate about 1V AC
Inspect the interior of the cap and distributor, for grease, oil, moisture, carbon tracking. Inspect the rotor carefully for spark "punch through."
Inspect the reluctor and pickup for strike damage, rust, and debri
With the distributor connector unhooked, and the key in run, take a grounded clip lead. Ground first one, then the other, of the two distributor connections going to the ECU. (I forget which one, try both). One of them should give you as spark each time you do this.
Does not hurt to pull the connectors off the ballast and ECU and "work" them in / out several times to "feel" for tightness and scrub the terminals.
