3404spdfish
I just cam across a pile, well small pile of 64ish 8.75 b body rear ends. I know they have tapered axles and the hub/drum are pressed on, however I noticed there 741 housings and almost all are sure grip or well something is going on in thee due to the fact that both axles spin the same direction. the question is since nothing else interchanges with my 8.75 do the center sections interchange. are the axles ends the same spline and diameter? some input here would be nice before I get to stripping them down
