j par
Well-hung Member
Now this is where you just keep close track maybe take pictures and definitely laying things out exactly the way they came out. You'll start pulling some different gears that mesh in between each other and they'll mesh right back in with each other. There's some brass washer spacers that have three little tangs on them that go in certain grooves. I'll explain when putting it back together how to get these in how to make them stay just basically coating them in Vaseline so they stick where you want them to stick while you get things put together. There's probably three four different pieces that come out at this point.
I get to the rear drum that the rear band is is wrapped around and you can take both those out at the same time together and put them together...
