Try it without the spacer.
Low speed light throttle only uses the idle circuit so it could be that you need to use lighter springs. The metering rod might be bouncing up and down . I dont think timing is an issue . I run a very similar cam and it will run OK anywhere between 12-18 intitial. I also think your lash is fine .
Try the lighter springs and see what they do .
The valve lash isn't the root of your running problems. The carburetor is still too lean.
I've been saying it all along.So basically a rod change?
it may be bouncing in drive though . Cant hurt to try .Orange springs in it, and down tight at idle. Pop up when throttled.
The spacer was needed when we 1st got the car for percolation. I honestly never thought about removing it.
I can’t imagine the spacer is causing this unless there is massu vacuum leak.
Anytime you add a spacer the calibration needs to be adjusted, usually needs richening up.
What else could cause the surging .I think the springs are about right, Steve. I wouldn't mess with those again right now. If the pistons are staying down SOLID at idle and not bouncing, leave the springs alone for now.
It's too lean.What else could cause the surging .
Metering rods are supposed to be down/lean in cruise and idle, sir. That's when vacuum is highest. When vacuum drops, the springs overcome the low vacuum and push the rods UP into the small (rich) part of the rods enriching the mixture for acceleration, similar to a power valve. But at a steady cruise while NOT under load, the rods are in the down (lean) position since vacuum is high. Sorry your gettin your panties in a wad, but thats how these carburetors work. He has the springs what I would call just about right.If the rods/pistons stay down at idle, they will stay down at cruise speed because the vacuum is higher.
This will be my last post on this thread because I see my advice [ posts 26 & 43 ] of 40+ yrs years on these carbs is being ignored.
For the umpteenth time, do the idle screw test in post #43 because you may well be still on the idle cct at cruise & THE MET RODS/ MAIN JETS WILL HAVE NO AFFECT IF THIS IS THE CASE, SO CHANGING THEM DOES NOTHING. And it needs more idle timing.
Here is my last piece of help:
T slot is checked from under the blades. Carb would normally have to be removed each time to check this. A pain in the a**. To check without removing the carb....with carb on the bench, set t slot to 0.040" [ ideal/perfect ] with speed screw. Using vernier calipers, measure from screw boss to head of screw & record it. Now open blades for a 0.060" gap. Measure again & record. With carb on the car, you can check your gap. More than 060 would require bypass air [ only after correct idle timing is established ]. Less than 040 is OK & no corrective action is needed. Your surging problems are quite likely T slot related. I would also set the valve lash to 0.030" which will improve idle vac.
Something radically wrong. if you can idle at 675 rpm, you should have more vac than 10.5"; similarly 750 rpm in Park would expect more than 13". Maybe faulty vac gauge?
Surging @ 38 mph could well be on the idle cct, NOT the main cct. Back out the idle mixture screws a full turn & re-test. If better or fixed, the idle tubes in the pri boosters need enlarging.
Unless you find the optimum idle timing that I outlined [ read the link ], then you are just p*ssing in the wind....& so are the rest of us that are trying to help you.
You are quoting pages from the Edel manual. Did you read the advice about using as much idle timing as possible, & using vac connected to man vacuum as a method of doing it?
Take your time and have fun. Try different things and learn as you go. Ignore the EGO's........Well, I did turn the IMS out as mentioned in #43, sorry you feel you're being ignored, you ain't the only one with advice here. Doing this by myself takes time. So unwad yerself and relax, or not...
Forgive me if I'm gettin this wrong, but the one time you made it richer, it got better, right?Well, I did turn the IMS out as mentioned in #43, sorry you feel you're being ignored, you ain't the only one with advice here. Doing this by myself takes time. So unwad yerself and relax, or not...
Also Steve, just like Edelbrock says. as you get closer to the optimal tune, the vacuum reading will continue to climb. So that's one other way to tell your heading in the right direction. But again, that's not set in stone, yet, because your timing may not be optimal for the tune yet. I don't know what method you've been using to adjust the idle air screws, but here's how I do it.
If it's an auto, I adjust IN gear with the wheels blocked and parking on. Don't wanna run anybody over. With the engine up to temp and your vacuum gauge hooked to a manifold vacuum source, I adjust them 1/4 turn IN (lean) at the time, until the vacuum on the gauge begins to drop and the engine starts to stumble. Next, I adjust OUT (rich) 1/4 turn at a time until I reach the highest reading on the vacuum gauge. The engine will smooth out once that highest reading is met. Rinse and repeat for the other screw. Opinions vary, but I prefer to make this adjustment with the idle "a little" lower then normal, because you can hear the differences in the way the engine runs and normally see the differences on the vacuum gauge easier, too. Not necessary, but it can help if you haven't done it enough to get used to hearing how the engine responds. If the idle is normal, say about 750, sometimes it will "cover up" so to speak the differences you need to be listening for while making those adjustments.....if that makes sense.
He should check the timing while he's at it.Also Steve, just like Edelbrock says. as you get closer to the optimal tune, the vacuum reading will continue to climb. So that's one other way to tell your heading in the right direction. But again, that's not set in stone, yet, because your timing may not be optimal for the tune yet. I don't know what method you've been using to adjust the idle air screws, but here's how I do it.
Kick the timing back up to 16, then check in gear.Thanks Rob, the one time I went 1 step up rich it was "better" but still had SOME surging/stumble.
So my next "changes" were
1- Set valve lash a little looser .018 int and .022 ex(comp says .022 for both)
2- reduce timing to 12* from 16*(mentioned on here)
3- increased idle(rpm dropped with timing) approx 1/4 turn.
4- opened IMS up another 1/2 turn to chk for changes.
This was my drive last night, nfg lol.
Honestly the ims screws make no difference until approx 1 1/2- 1 1/4 turns out....from 1 1/2- 2 turns there is next to no difference.
Did you say you also had a 1406? I wonder if you should pop it on there just to see if there's a quirk in the 1405. 1406s come set up a little lean, so if you have a set of 7347 or 7147 rods, you may want to pop them in. If not, you can still do a comparison.
I set my initial in gear
