Just be aware that the early 340 manifolds cost a lot more than they did 15-20 years ago. I sold mine for enough money to pay for the TTI headers.
And they make little difference unless you wind the crap out of the engine
Well, I'm gonna have to disagree with that. Headers don't just add power up top, they add a bunch of torque; they help a lot everywhere. The difference was amazing to me.And they make little difference unless you wind the crap out of the engine
Now if only someone would make one for a slant six.I’m sold on aluminum heads on any small block for lots of reasons.
I agree with this all I did was take the hard square edge off. I Was Scared of Water. Was better to remove it from the manifold and use thick gaskets.So, first, the grind on the head method...Some have done it & gotten away with it.... Some like Steve Dulcich have found water.... What I did was use an old header flange as a spacer.... Moved the manifold out about 5/16" giving about 1/8" clearance..
Probably true, but my 340's power noticeably improved just swapping from OEM to Edelbrock heads on my 340, while keeping the stock exhaust manifolds. Of course, it runs better now that it has headers.I don't believe Edelbrock (or anyone else for that matter) made aluminum heads with the thought that anyone would ever run exhaust manifolds on them.
If you decide to keep the headers but need the reduced heat running electric fans a can help a lot if you are driving in traffic.Headers make a significant difference in performance but the trade off is a personal choice. I choose to have stock manifolds for several reasons including heat and clearance.
I haven't tried it but running a thicker remflex gasket or even doubling gaskets on that side may work.So, first, the grind on the head method...Some have done it & gotten away with it.... Some like Steve Dulcich have found water.... What I did was use an old header flange as a spacer.... Moved the manifold out about 5/16" giving about 1/8" clearance..
I personally wouldn’t try double exhaust gaskets. It may hold, but I’m not too warm and fuzzy on the idea. Worth a shot!I haven't tried it but running a thicker remflex gasket or even doubling gaskets on that side may work.
I second that. Even on a very mild cam and compression engine, it’s a winner.IMO, knowing what I now know thanks to those experienced with this endeavor and as expensive as heads, headers and even factory 340 exhaust manifolds are anymore I'd lean more towards either spacing the stock manifolds out or headers.
I can tell you it won't fit. Been there, done that. Because of the shape of the manifold, it hits the head where the manifold curls under. I tried removing some of the manifold material, but too much material needed to be removed for my comfort. I got a header flange to act as a spacer. You'll have to use 2 gaskets, 1 between the flange and the head and 1 between the manifold and the flange. There's probably a better way, but that's how I solved it. I did speak with a tech from Edelbrock, but they couldn't offer a solution.I was wondering if anyone has had any experience with using any OEM stock manifolds with the edelbrock heads on a small block 340 a body
9.5:1 on the Aluminum head cars. Had 8:5:1 on my stock steel head 318. All run plates to allow 18 degrees idle and 30 all in. Cams are all low duration hitting around 7.5 dynamic and 185 PSI cranking (the cast head build was lower) My car with the stock cast heads and low compression pinged like a bugger and struggled with over heating in traffic. Both the aluminum head 318 and 360 have never pinged and run cool. All radiators are 4 core done by GlenRay.
I've noticed the Magnum interference, too. It's not as major of an interference, but it's there. I'm sure it varies due to manufacturing tolerances, but in my situation a thick gasket cleared it up, didn't have to resort to the header flange fix in that case.I've also had similar experience, the 5.9/360 in my Duster has ported Edelbrocks and 9:1 compression while the 360 in my D200 has stock iron heads and 8:1 compression (rated 8.2:1 but likely lower). I've never had the Duster engine ping even when the ignition timing was overly advanced but the truck engine pings like a SOB especially in hot weather if it has just a little bit too much advance.
To add to the OP's original question, I've had issues with an early 340 driver side manifold interfering with a factory Magnum head in that same location as the Edelbrocks.
