josuevalenza
Active Member
Hi everyone, do you think a 340 Edelbrock Torker II will fit a '66 273 V8? If it fits, are there any modifications that need to be made? I got the manifold and carburetor for $200, practically new.
Apparently there is a pin that does not allow the manifold to fit perfectly on the engine. it is a 66 273, the carburetor is a 4-barrel Edelbrock.it will physically fit, provided the heads are actually 66 units and not the earlier ones with the different bolt size and angle.
however, the port match is going to be horrendous.
and if you've got a stock cam, and you're running what i'll assume is a big carb for that manifold it's going to run not great at all.
Edit: what carb?
maybe it's useful to you and you can keep that and sell the manifold and get something more appropriate.
Engine is stock, been working well with the 2bl holley, trans is 4 speed.
- you can pull that pin out.
- 273 ports are like 318 ports, I wouldn't worry about the port size.
- What I would worry about is this intakes designed purpose vs your engine. If your engine is stock, or remotely close to stock, I wouldn't recommend that intake.
That intake is pretty racy for a 273 2 barrel and depending on what carb, a smaller carb might be a better choice. It will bolt up and work but...........there are better choices.Engine is stock, been working well with the 2bl holley, trans is 4 speed.
Motor is Stock, here are some picsthe pin can be removed-- i'm guessing you're talking about the one on the rail between the cylinder banks.
which edelbrock part number?
and what are the specs of the motor?
Yeah, that pin pulls out. Lock on to it with a grips.Motor is Stock, here are some pics
1930 Ford A roadsteri gotta ask, what is the project? What frame?
If it's never going to be really hot rodded, and just cruise to the local shows or Dairy Queen, that intake will work for that. Especially with the 4 speed. People put rough idle cams and tunnel rams on stock engines for stuff like that, for looks and sound not caring about performance. But, as stated, better intakes for it than that torker II1930 Ford A roadster
that pin is for locating stock manifolds. frequently they're gone anyway. conversely, you could drill you intake to fit.
anyway, what i was getting at is that's a manifold designed for more cubic inches and high RPM operation. it is not a great match for most stock engines.
can it be made to work? sure. but there's better options out there. and depending on what you've got-- weight of vehicle, gears, cam, type of driving you're going to do, there's alot better options out there.
Thanks for the reply, unfortunately here in Peru there aren't many spare parts for Mopar, the project is a Ford A roadster, the truth is that I'm looking for the engine to look good and run better, no racing, no drag, just a cruiser, but I can't install the shotgun in a 2-barrel carburetor, that's why I chose this one that came with everything included, the 4-barrel carburetor.that pin is for locating stock manifolds. frequently they're gone anyway. conversely, you could drill you intake to fit.
Exactly, it's a car for Sunday shows, going out for a coffee, maybe using it 2 days a week and no more than that, it's not a car for the track, for drag or racing, this engine already sounds wonderful, the idea is for it to look good, sound great and drive better.If it's never going to be really hot rodded, and just cruise to the local shows or Dairy Queen, that intake will work for that. Especially with the 4 speed. People put rough idle cams and tunnel rams on stock engines for stuff like that, for looks and sound not caring about performance. But, as stated, better intakes for it than that torker II
Then pull that pin and onward! Show us a picture of the car when completed!Exactly, it's a car for Sunday shows, going out for a coffee, maybe using it 2 days a week and no more than that, it's not a car for the track, for drag or racing, this engine already sounds wonderful, the idea is for it to look good, sound great and drive better.
I wonder if that would make a difference in Peru????Tell em it's a 340.
Well then, tell em it's a 6 liter (.030 over 360) lol.I wonder if that would make a difference in Peru????
Read that sentence over and over and over until it hits you.Engine is stock, been working well with the 2bl holley, trans is 4 speed.
That rolled pin on the china wall? You can pull it with a pair of pliers.Apparently there is a pin that does not allow the manifold to fit perfectly on the engine. it is a 66 273, the carburetor is a 4-barrel Edelbrock.
Lima - Sea level.Altitude? Sea level, or waaaaay up in the Andes?
