If you decide to run a mechanical fan assy with or without a clutch keep in mind there are larger diameter blades available for either. I have a MP clutch with a larger fan blade assy on it on my street car and the engine stays at 180 even in the heat (only 100 here in Massachusetts) although I must say the biggest contributer of heat is an automatic transmission. My car is a stick and runs way cooler than when it had an automatic in it 20 years ago. Again street car, not my Valiant.
