"Internal Combustion Engines and Air Pollution" by Edward F Obert
You can also read the various snips from Obert, Larew, and Taylor that Tuner and Shrinker in particular have posted and explained on a few forums, which some of us here have referenced in the past.
The clue here is rich idle, lean cruise, leaner (leanest, actually) part-throttle acceleration and rich WOT. The leanest is at mid-load, half-thrott
www.tapatalk.com
Paper on Air Bleeds
www.tapatalk.com
For the past few years I've been able to use a Sun 404 machine. But its not that close to here, and sometimes it needs some servicing (that is, I ha
www.tapatalk.com
What happens if there is too much timing advance under cruise or engine braking? Will there still be detonation? Will it simply misfire? I ask because
www.tapatalk.com
I am going to get some vacuum line this weekend so I can put the gauge in the car and check cruise vacuum.
www.forabodiesonly.com
Stock 5.9 magnum=3310 vac sec 750 380 crate magnum =750 double pumper Done and done. This^^^ Or fix the 4777. There's really nothing to wear on it. So if its 'shot' in that its not running right but it used to, then its something simple; Dirt in passageway, leak from accelerator pump...
It depends on the booster. I’m very green on these boosters, but what I’m finding out is the better boosters are a SLIGHT CFM air reduction. Which, comes back around to the old saying “not all airflow is good airflow”. If a slight reduction in air flow cleans up distribution, allows less total...
Of course some people think that those old books are outdated because engines now work differently. The funny thing is those guys had to make engines work well with the mighty spark of points ignitions, and couldn't try to hide timing or combustion conditions with a flamethrower ignitions.
