Emergency brake and sub frame connectors
PatrioticMopar
Active Member
Utah
Hi all,
I have a new e-brake to install on my 72 Duster project. I already have subframe connectors welded in and now the normal “path” for the cable is blocked.
Would it be best to:
A) drill an angled hole in the subframe connector to try an maintain the original pathing?
B) Is there a custom kit out there for this exact problem?
C) find an alternative routing for the cable?
Thanks in advance!
i think when i did mine, i just drilled a hole somewhere and rerouted it
(i know, not very helpful)
but then again, i never use my park brake and couldnt care less
I had the same problem. I just drilled a new hole above the old one, which is going to get blocked off by the sub frame connector. Measure carefully, my cable had a smaller diameter on the rear-end side than the front-end side of the fitting that goes through the frame.
Thanks for the confirmation guys. I’ll drill it :thumbsup:
thats right!
two different sized holes, to keep it functional
Heres what I did to route it alongside the connector. First pic is the front view looking back. The front hole that the cable is inside is 3/4" The connector was not welded in yet at the time these pix were taken.
I drilled 2 slots one for an entrance and one for an exit in the subframe connector in line with the original cable path.
I also drilled thru the connector and spot welded a piece of steel tubing in at an angle for the cable to pass.
