Check the fendertag. Should read 32 under AB.I have a 66 formula s with a A273 hippo in t , could the engine have been a left over that got put in my 66
Welcome to FABO. What exactly is your question?I have a 66 formula s with a A273 hippo in t , could the engine have been a left over that got put in my 66
I wouldn't worry about the "A" 273. 273's came out in 64 so you would think the A would be the first release? Is that what you are thinking? What is the casting number? 2465330 is 64-66 and 2536130 is 65 only. 2806130 is 67-69 "4-27" is just a month and day. Nothing to do with year.Professor Fate trying to get info on if the A273 4-27 could have been put in my (c2300107 fender rage) 66 car
So it's a 65. Or the heads are anyway. Was it a left over from 65 into your 66? Anything is possible but probably not. What's the build date on your car. It would have to be a early August build to receive a leftover 65 engine.It’s a 2465330 I’ve looked inside it has dome pictons , the intake has the early bolt pattern
